Hi, is there any option to setup queuing system like you are number 1 in the que....., in UC 540W?
Hi,I need to display Caller ID visually (light LED on attendant console).For example:I have 20 SIP extensions 100-120, my phone is number 100.If 101 call me -> light the first LED on attendant consoleIf 102 call me -> light the second LED on attendat...
Hi everyone,Our customer (and i) complains about slow call setup when doing outbound calls from SPA phones on UC560-BRI-K9.User types the called number and presses the Dial button on the phone and it takes around 10 seconds for the call to go out on ...
Is this Configuration is possible to integrate 2 UC from 2 different site?
Hello,When using a SPA-932 attached to an SPA-962, I am trying to figure out how to perform a transfer on an Asterisk PBX. I have tried setting fnc=sd;sub=#700@asterisk-ip on one of the line keys where # is the transfer key and 700 is the extension t...
SPA502G, software ver. 7.5.5, Hardware ver. 104DHCP server conf.:ip dhcp pool VOIP network 10.1.6.128 255.255.255.224 domain-name iib.ua dns-server 10.0.2.11 10.0.2.24 default-router 10.1.6.129 option 42 ip 10.0.2.29 10.0.2.35 option 66 ascii 10.1...
Its a SPA2102.There is a 60Hz noise (from power line)What can be done to reduce or eliminate it ?
Hi,I have a little problem with some SPA514G and my UC320W.My configuration is simple, we have a UC320W with a sip trunk to my service provider and we have 6 SPA514G.Everything works fine for internal call and external call trough my SIP provider but...
How to support CP-524S ip phone in UC320W ?, UC320W support to SPA 500 series and SPA300 series, i'am force registration CP-524S to UC320W
Hi, I have an adapter which has an odd issue with not being able to answer an incoming call. Outbound is clear quality and working great on both line-1 and line2.SCENARIO: Inbound call comes from provider, phone rings and displays caller-ID. I answer...
I need to set up the prefix '10787' for all outgoing calls and recall numbers, for example, if the custumber dial 0934902738 the system hace to dial 10787934902738 but the '10787' have to be invisible for the customer.I work also with Panasonic's PBX...
Hello,Does anyone know how to specify what goes out on this, the ISP says I cannot forward calls to the outside unless I specify the number. Right now it is sending :504"Redirecting Number i 0x00085, "504Thanks for the help
HiHave a UC540 and a couple of SPA502 & SPA303's which have been setup and are working pretty well. I am trying to add a SPA901 phone and not having much luck. If i set the SPA901 to DHCP it gets an ip on the data vlan not the voice vlan. If I giv...
How to create a post request for a spa 525g2. For spa 504g such a request is valid:http://192.168.2.113/CGI/ExecutePOST /CGI/Execute HTTP/1.1Host: 192.168.2.113Accept: */*Content-Type: text/xml; charset="UTF-8"Content-Length: 92XML=<CiscoIPPhoneExecu...
HiIs it possible to limit access to the SPA504G phone menu? What I mean is not GUI access; I read provisioning documentation and set ua=”na” in xml tags, but it just limited GUI access. Also, I set a password for user, but it limited all phone functi...
