Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hi,I want to know about the followings support,Firstly, does UC 540 support CME 8.6? if yes then is it support SPA 500 series phones? if yes then can UC-540 register these phones over WAN using SSL vpn tunnels?Second, does cisco jabber in iPhone supp...
Hi,I can't restore .cfg files on the Config Management menu. The "browse" buttonis not active and i can't load a file. The firmware version is 1.3.1. Tested with Firefox, Opera, Google ChromeInternet Explorer (old V6), same results. I haven't got pro...
Hello everyone, I have a UC560 with 3 Auto Attendants and BACD. We are having intermittent issues where calls are in queue and are not being delivered.  Some users in the hunt group receive the calls, but others intermittently will not. They will see...
I have an AA set up to answer all incoming calls and transfer calls to 2 separate BACD group depending on what key is pressed.  This seems to be causing CUE to hang and ring busy at times.  Reloading CUE fixes the problem.  STAC has told me that the ...
Hello,I have one UC540 with BRI Card and one UC560 with FXO Card.I would like to swap the BRI Card and FXO Card.Is supported by Cisco ?Is it possible ?and if yes I just need to power off the UC and swap the card ?Thank you,Sent from Cisco Technical S...
All-In a previous post, I asked, and was answered about 7.5.4 not 'sticking' for certain phones. https://supportforums.cisco.com/thread/2216529What I'm observing to be more specific is that the 7.5.4 is applied successfully (or so it appears on the d...
I purchased a WRP400 wi-fi router (two SIP VoIP ATA ports) and loaded the latest firmware (2.00.32). This code is bugware. Not only do the configuration screens not work properly in FIrefox (it keeps giving "your connection has been reset by the peer...
carlb1613 by Level 1
  • 1124 Views
  • 1 replies
                 Comprei Um UC 500 mas não consigo configurar aparelhos do Modelo SPA 941, no modelo SPA502G configura corretamete, verifiquei que tem como fazer upload de outros modelos de telefone mas não encontro em lugar algum, alquem tem ideia o...
I am unable to get IP Communicator to register on my UC520. My guess is there is a problem with the routing somewhere, but have not been able to resolve the issue.  So I'm turning to the community for help.Network is set up as follows:  modem --> rou...
Hello,for testing of some software I need first to make sure that the analog phone connected to the SPA3102 will receive an incoming call.I have an analog line that comes from Alcatel Omni PCX4400. 1. The plain analog phone connected to the line RING...
