Hi,I've looked throug the BE3000 documentation and can find no mention of recording profiles being supported on this platform. Do we need to do SPAN based recording on this rather than SIP forking?CheersJamie
Hi the current config is: The calls come in on the ext.21 if no one answers than the calls will forwarded to a call blast group after three times ringing the custemers get a message "all agent are busy" but when the customers hears the message the ph...
HI, I am trying to connect two offices, with wireless bridge my client has at the principal office, RV042- - - -UC320W(this works as DHCP for voice and data)- - - -SG100-16 Switch- - - NS5 Ubiquiti antena( Bridge-Accespoint)- - - Street- - -(second...
Hello,I am fairly new to PBX system. I have recently set up a UC320W with an external SIP trunk. It seems to be registring with the SIP provider correctly and I am able to call in with my cell phone and it gets routed correctly to one of 3 SPA504G ph...
Hello,We have two sites each with a UC520 – HQ and Branch. Can they be set up so the HQ has SIP to our Telco provider for PSTN access and the branch uses the SIP connection from the HQ over IPSec?Also our CEO needs a phone at the branch with his HQ e...
Does anyone know a command line script that can periodically soft reboot the SPA112? Firmware 1.2.1 still hasn't fixed the uptime issues and the unit reguarly locks up after 2-3 days with no dial tones and response to web admin requests. You then nee...
Hi All, I have a SPA112 brain new, with latest fw loaded as per Cisco site Version 1.2.1 (004)Since the first installation has started to show the same problem as described also in " SPA112 Crashes - No dialtone, restart needed...
Does anybody know how to configure the 3CX soft PBX so that the MWI works properly on the Cisco SPA303 and SPA 525G phones?I find that if you set Message Waiting on any extension in the phone's web interface to "Yes" the MWI comes on and stays on whe...
Good morning, I've a spa502G phone and cme 8.0.The phone is compatible with my cme?If yes I need to have the phone firmware but I'dont have access to download firmware from the cisco webasite, Anyone can help me?Thanks in advanceGiancarlo ...
How to configure Cisco SPA8800 connectivity to Lync Server 2010. The entire infrastructure are compose of Windows Server 2008 R2 64-bit as AD with Hyper-V of Exchange 2003 on a Windows 2003 Standard 32-bit, Lync Server 2010 (all are colocated) on Win...
I am sending logs to my syslog server from my SPA122 but also want to be able to view them on the device in the case that there's a device issue and it can't send out to the syslog server. If I were to log kernel & system in the "Log Module," what's ...
New unit with latest firmware (1.2.1). SPA112 qualify response times are usually between 48-60 ms (my polycom phones are 5-6). After some number of hours, it suddenly won't respond to the once a minute asterisk qualify and returns very long respons...
First off can users with SNR or shared extensions work with ACD? I'm following the guide but can't get anything to work.I made a basic ACD called 515 as the pilot number with all basic settings and put 2 of my extensions as members. I then put on m...
I'm testing an SPA112 with firmware version "1.2.0 (042) Jul 5 2012" to see if some of the previous DTMF issues have been resolved.We have analog devices sitting behind the ATA that require DTMF tones to be played for at least 1 second to be acknowle...
