Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
I just bought a Cisco soma 303 IP phone for use with my AT&T BGW210 gateway.I hooked up the phone to an ethernet port on the gateway and have power to the phone.  The instructions only included the physical setup of the phone (power/ ethernet) etc.  ...
Welcome to this guide.  Today you will learn how to properly set up a Cisco UC520 as a New and used device.  The first section will be for a NEW UC520.  NEW UC520Step 1- Start your UC520 by plugging it in.  Make sure you plug your Laptop or PC into o...
yarusemi1 by Level 1
  • 2370 Views
  • 0 replies
  • 5 Helpful votes
From the information I've found scattered around the internet, the PAP2T seem to be a later version of the PAP2 with more memory and the ability to support two concurrent g.729 calls. I have a large number of devices identifying themselves as "Linksy...
Good morning , I'm trying to set up a voip network for my company . We've a small office with a British Telecom ISDN2e connection.The ISDN has 2 cables with 8 numbers on it . We have recently replaced a broken phone switchboard with a Cisco 2811 solu...
w4rrior2k by Level 1
  • 908 Views
  • 1 replies
Hi!I have a Panasonic wireless phone at home, connected to the SPA112 which is connected to an Asus Router so I can use the phone via VoIP. Outbound calls are working fine, incoming calls too, but the inbound number is not displayed on my phone (only...
Jonatan by Level 1
  • 945 Views
  • 1 replies
Seems since the new Call Appearance per line has been implented Vertical First does not work as intended. I noticed a prior case that was resolved but for private lines, however for Shared lines this issue was not fixed.2nd+ calls indeed still ring o...
hi_tecc11 by Level 1
  • 1301 Views
  • 2 replies
Hello,         We have several cicso spa phones with us(303,504).However we observed a problem with these phones when we are using the shared line appearance feature.       I have 3 line appearances for the same user on the phone , so that i can perf...
With a VG224 set up with 4 number dialing (number range is 11xx, 85xx and 89xx across multiple VG224), the issue I'm having  is that when the analogue phone goes off hook I intermittently get no dial tone and after a while I get a message to check th...
I have a SPA112 connected to a Virgin Super Hub 3.It will make outgoing domestic calls, but it's not ringing for incoming calls.I've set up port filtering:Local ExternalPort range Port range Protocol5060-50805060-5080BOTH3478-34783478-3478UDP1720-172...
