i have a 2N Helios IP door entry phone How can i get this to work with My UC560 ?Thank you.
I have a client that has a UC540 with a PRI w/23 channels of voice and 25 DIDs. He is wanting to get rid of the PRI and go with a SIP provider (preferably skype) but wants to keep at least 9 of his DIDs and his main number which rolls over to 3 othe...
So we have been fighting a bug for a long time now, and really want to find some kind of workaround for our customers.The issue is: non-outlook imap clients (ESPECIALLY iPhones) cause mailboxes to "lock up" and get stuck in some sort of error message...
Hi, i try to configure , my SPA122 and linksys, but i need your help ,,,My ISP is Videotron with Ip Staticthe WAN go on SPA122 and after go in the Wan router LinksysMy config of SPA122 is Network Service = NATInternet Connection = Static IP (some par...
Hi All,I hope the subject heading is not to ambiguous, but I am struggling with a particular issue that is causing me some headaches, simply because the System is not working as advertised and I have no clean explanation to the client as to why I can...
Looking at an opportunity with 200 analog devices. Is there a limit on the number of VG224 Gateways that are supported on the BE3000?
Hi,Anyone else having any issues where the UC320 is answering calls immediately. Configuration not changed from working normally and the box has just started to answer calls immediately - sometimes you here a ringing tone for approx half a second bu...
I am trying to configure a UC540 with the 4fxo and 4fxs ports for a customer. The equipment was bought used so I first had to do a password recovery and then I went ahead and erased the old config because it was not applicable to what I needed confi...
Hi All,Currently implementing a UC540 with 6 x SPA514G phones.I ran through the CCA Telephony Wizard and was able to add one of the phones without issue.Since then I have tried addding more 514G's through CCA Users/ExtensionsCCA finds the phones, but...
Hi All,Recently install a UC300 system with a handful of SPA504g. The system is working fine but I would like more sidetone ' more of myself' in the handset. I can hear a little but I would like more. We have come from a Panasonic analog system whic...
Hello,Can anyone guve a clear answer to this question : Are the Cisco 8941 / 8945 supported phones on the UC560 ? If so, what is the video experience on it ? Is working well evebn on a such small box ? Regards
We have one client who will need a phone set up in a conference room. Is there anything like the Cisco CP-7937G that is compatible with the UC320? Something like: http://www.buy.com/prod/cisco-unified-7937g-ip-conference-station-10-100base-tx-deskt...
My newly purchased SPA122 ATA with router crashes regularly, (daily) , no dial tone, no internet going through.Only power on/off gets it working again !Using the latest 1.2.1 (004) 2012 Summer firmware.Many post mentioned, that disabling many unwante...
I am having issues with an SPA880 attached to a UC320. All of my lines test good and work fine when hooked up directly to UC320. When I plug any line into the SPA8800 expansion box, the lines only work part of the time. When they quit working, the...
I am having trouble with WAN port connectivity. I am using the Greyfield Scenario (UC320W Routes voice only). My preference would be to simply use the DATA LAN (VLAN1) to give the UC320W WAN an IP address, or statically assign one in the LAN network,...
