Hi!!I would like to know how many PVDM came with the PN: UC560W-FXO-K9 ??? Is possible to upgrade the PVDM on this equipment??? Now I need to license the UC560W-FXO-K9 for 40 users. Tks! Márcio Rossetti
Hi thereI have just upgraded a clients UC320W to 2.1.4 - and the dial plan for NZ mobile numbers now does not support 028 numbers - format 028xxxxxx. I tried all other valid 02x numbers (which are the other mobile networks) but 028 returns a number u...
Just bougth a Cisco Router E4200-ME top of the range, High Performer and only 3 easy step to get you going. This has turn out to be my worse nigthmare of 2012. Followed the 3 step simple instruction but didnt work. Called the supplier point of sale n...
Hello!!!I have 2 error in CCA with the telephony wizard:- the first one is attached, when the UC is factory default, the first wizard search the config and make this error.- after 2 or 3 times I launch the wizard It is working!!! but I complete all s...
Hi! My IP phone SPA941 suddenly refused to work. It lighted up 3 yellow leds (choose of line) and LCD went off. After cutting the power, it doesn't respond to any keys. LCD still off. All leds - off. AC adapter is ok - 5V. Tried to connect it directl...
Hi,I'm a small home office user of the SPA2102. I've spent an hour on the phone today to MyNetFone trying to resolve this issue without success, so hope some help may be available here:1. I have a Brother MFC-9120CN multifunction plugged into line 2...
I'm having a problem where people are checking their voicemail and sometimes it'snot accepting their PIN from the Cisco phone. I've had people try a number of times without being able to log in, others can get in on the first or second try. Calling ...
Hi all,maybe somebody can help me. I installed a UC320W. Only a SIP Trunk is used as line.Everything works fine except CLIDIf you call outside, on the called phone only the no. without ext. is showed.SIP provider checked his logfiles - he receives on...
The 10-users will have a mix of SPA phones.What is needed to get the remote site to be part of the 560 so that the phones register withit?I am only looking for the hardware and taking into consideration no local PSTN at the remote site.Would I supply...
Hi guys, I have been searching all over the site and I cannot find the location or any documents on how to change the languages of the 7942 and 7965 when the phones are running in SIP mode and not controlled by the CCM.I have found information regard...
Hi!I have discovered, that there are no SPA telephones under the "load" command in "Telephony-service" section.There are only 6xxx and 7xxx types.Is there any way to configure SPA telephones in CME 9.0? Or this is only IOS question?Regards,Aleksei
Hello,I have working setup with one SPA500S attendant console attached to SPA504G phone. Now I need attach second set of SPA504G+SPA500S to SPA9000 and it is not working.The problem is, that appearance leds on SPA500S are flapping. Only one SPA5...
Is there a guide, a how-to for connecting a Linksys SPA3102 with a Call Manager 7.x somewhere?I'm connected to LINE 1 set to port 5060Have been able to registered to call manager as a third party sip phone, can receive calls on the analog phone conne...
Good morning,we are using Asterisk and SPA3102 to connect a PSTN line.Our PSTN number is 123.We wish to call an internal "xxx" number (SPA send an INVITE to xxx), calling 123xxx from another PSTN phone.We cannot send an invite to "xxx" directly, but ...
Can i setup 2 UC500 system on different location using VPN & sharing only 1 PSTN or ISDN connection on both side? how?Regards,Angelo
