Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
I have 2 phones that are both doing the same thing.after resetting them the are stuck in a continuous reboot and sitting at the cisco screen with a target symbol at the bottom left.Any ideas what i should try?the loads are in my UC520 system, and we ...
mross1572 by Level 1
  • 1050 Views
  • 1 replies
Hello,I try to send a SUBSCRIBE to the SPA for the BLF :SUBSCRIBE sip:90768412622@50.20.20.8:5060;transport=tcp SIP/2.0.Call-ID: f2b4e8cc52f9fd6296060f15728c732c@50.20.20.92.CSeq: 1 SUBSCRIBE.From: "cisco" <sip:48@50.20.20.92>;tag=1326586390729.To: "...
Hi There,We have requirement to provide an analogue fax line in a client that has a UC560 at Head Office, a leased line to a sattlite office, and 6 phones setup.We purchased the VG202, but as its not a CCA configurable device, I have no idea where to...
graeme by Level 1
  • 1071 Views
  • 1 replies
Hi,Is there anyone who can point me in the direction of how to setup SIP to accept T38 calls and pass to an analogue FAX machine on an FXS port.I google and can see verious people with the issue on CME put no definitive answer.There has to be some wa...
graeme by Level 1
  • 1273 Views
  • 1 replies
Hi all,I'm aware of what I am calling the "test" XML harness that is available on our UC 560. IE: http://ip.add.re.ss/xml-test.html . We have a few questions, for example, using the B-ACD reporting, we can get the basic details on the activity in our...
I recommend Cisco to add feature that allow to automatically delete he message from uc500 VM when it send to exchange or any email server make this optional really it will help alot or atleast give an option to notify user by email when his voice mai...
The manual talks about disabling DHCP but i can't find anywhere that switches it off. We want to have one switch port for the clients PC and IP Phone and have each use a different router to access the internet. We will use the clients current router ...
Hi, I have just installed an SPA9000 but i am using the standard DIAL PLAN as when i chose localization in the setup wizard i could place any calls at all.This is what is set as my dial plan: -(9,[3469]11S0|9,<:1408>[2-9]xxxxxx|9,<:1>[2-9]xxxxxxxxxS0...
bodgeup by Level 1
  • 4651 Views
  • 2 replies
Adding "VOIP Unlimited" SIP Trunk ITSP into CCA Please create a XML template for CCA with the following details Name of ITSP                     Voip Unlimited Dialplan localeUK Display Proxy Server (Primary) fieldNo - use sip.voip-unlimited.net Disp...
Hi,I am currently installing a paging system to work with the UC320 phone system. The Paging system is from Viking Electronics (PA-30) with 6 paging horns.I currently have a night bell relay from my timeclock hooked up, and the system works great. Ve...
Hi TeamNeed a quick help.We did a UC320W setup for a customer with 6 handsets. Their is Auto attendant that is activated by a Force Night Button.This customer has Phone line from a Carrier that are IP lines. But these lines are provisioned through an...
Hello,we start with the UC320 under our traditional pbx - works OK for us tekkies.Then, when we try to connect with the ISDN Lines, we noticed, that we cannet call numbers that not start with 0.So, 999999 will not work, with local numbers it works: 0...
