Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
So I see with one address/location setting up a phone extension 911 and then forwarding any calls to that phone dials 9,911.  What I don't see is how do you do this when you have multiple buildings with phone service/trunk at each building?  If you a...
maacke285 by Level 1
  • 628 Views
  • 1 replies
Breif: CME 7.0 on 2901  Connected, on the right vlan, can http, did fact reset, shows in arp table. still nothing I've tried 2 different firmware versions and manual entried. 3.02.04 and 3.02.00   On Switch: GC_Ghost_SW#sh cdp neighborsCapability Cod...
Texas just came out with a new law requiring phone systems / phones to be able to directly dial 911 without having to dial 9 to get an outside line. You must be able to take the phone off hook and dial 911 and get an emergency responder. Can I get th...
Andy R. by Level 1
  • 2526 Views
  • 7 replies
I just got a SPA525G2 with HW version 2.1.0 or 2.0.1 ( I don't remember exactly what it was before an attempt to overcome the FW update problem went wrong) The original FW on the phone was 7.4.9 and I tried to update to 7.5.2b using SPA30x_SPA50x_7-5...
I have a Spa112 that I am using both line one and line 2. I have it running into an Avaya IP Office 500 V2.    Call comes in, caller has the option to dial a number to reach a tech in the field, call on line 1 is conferences to line 2 and connects to...
I have been trying to set up a Cisco SPA 122, but i am having a problem getting it to register. I am able to contact the PBX via Telnet on the ATA device, and i can see the incoming connections on the PBX, but the registration is failing and the Lin...
Hello, our company StarTrinity.com would like to use thousands of Cisco SPA112 ATA devices to customer's monitor IP networks between client and cloud IP PBX, using media loopback (see https://supportforums.cisco.com/t5/atas-gateways-and-accessories/s...
We have an SPA502G running 7.6.2c firmware.When an invite is received by the phone with no SDP and the call is answered the handset sends its OK response with SDP but then terminates the call.If the same handset receives an invite with SDP all is OK....
TheBBS by Level 1
  • 1108 Views
  • 5 replies
Resolved! SPA112 problem
Hi,   I have a SPA112 that was working fine for 6 months. Today, someone called me, it rang one time than it's stopped.   Since then, I was not able to make a single phone call.   The only port I was using was "Phone 1".  The light flashes green all ...
VinnyB by Level 1
  • 5231 Views
  • 9 replies
i want to disable a feature in the spa 514G and spa504G phones . let me explain  when i go to missing calls and checking it , once i left of the handset the phone auto call the missing number on the screen .  the phone should be in idle when i am usi...
