Advice Appreciated - Please could anyone advise where I might read about how to do this? What software in PC is needed? (is Skype an option?)do I need to configure the SPA942 itself?
I recently upgraded my CCA from 2.2.6 to 3.1.1, and decided I would try to upgrade my software pack as well to 8.2. Well, I figured out that my Firewall was causing some of the trouble, so allowed port UDP 69 (TFTP) access, and after that the upgrad...
Is there a way to mute the tones the phone makes when you pre-dial and then push dial or go off-hook? I understand it is actually dialing to the UC but it is annoying...Thanks.
Hi,We have a client with a multisite setup UC560 in main site, with SIP trunk incoming, UC540 remote site as site 2, no SIP Trunk.All incoming and outgoing calls Via SIP on Site 1We have setup floaiting externsions on both sites so the users dails 30...
Hello, I have a two sites' environment with an UC520 (2xBRI) on each and the customer want to be able to use all the pstn lines available at both sites.This means, if a site has all the pstn lines busy the call is routed to the other UC500, is that p...
I have installed two separate systems comprised of one SPA900 and one SPA3102 in diffferent locations about a year ago and are both presenting the following problem.There is one analog phone connected to one of the FXS ports on the SPA9000When one SP...
Could you plese confirm if the following dial plans will work? In both cases I include the "9," to steer the call and are part of alonger string that is proven to work.In the following example I would like to use three different codes (passwords) to...
Hi, I have recently installed the UC 320W in India and need help resolving the following issues. 1) Is there a plan to release a region pack for India. I am currently using the US region with the 10 digit dial plan, but I am assuming that it also may...
I have set up 1 phone number out of 8 to go to a specific extension. I want to be able to present that one number (when it is dialed directly or dialed from) to present itself to the receivers caller ID. All other numbers show up as the "main" number...
Seen few discussions here but still stuck on Cisco logoI've tried to press speaker buttons (several times) as soon as the cisco loge comes up but nothing.Last thing I did to the phone was changing the DST configuration. After reboot, stuck on cisco ...
Hi, we have a problem with some SPA525G2 and SPA502 registered to a Alcatel's Softswitch. The problem is that this phones can only make 3-Way conferences and we need them to be able to make N-party conferences. They are using SIP. Is there something ...
When an outside call is received on the UC320W and that same call is transferred to another outside number via an outbound trunk even after the call completes the outside trunks freeze and no one is able to use them until they are disconnected and re...
