Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
I'm assuming the answer is no but it is possible to force a resync even if the "Provision Enable" option is set to No?    The phones in question have Auth-Resync-Reboot set to Yes. So the notify message would be authenticated. I verified the reverse ...
andrew011 by Level 1
  • 1372 Views
  • 1 replies
I have purchased a SPA112 ATA, connected it, obtained through the IVR the address, and when I try to connect to the configuration page using the default password admin, I notice about ten more dots added automatically to the password field, and the p...
chrispapx by Level 1
  • 1257 Views
  • 4 replies
We use Kamailio as a router and would like to catch first registration requests from rebooted Cisco phones to perform certain actions. Is there a way to determine first registration SIP message comming to the Kamailio from rebooted Cisco phones?
adeykunov by Level 1
  • 648 Views
  • 1 replies
Most vendors reset CSEQ counter to 0 after device rebooting and, therefore, at the router side I can determine whether it was a first SIP request from the restarted device or not. But Cisco devices don't reset this counter by default. Is there a way ...
  • 685 Views
  • 1 replies
     Hi All, I need to setup UC540 in a existing network using the existing DHCP server, the dhcp provides also the default gateway to the clients, this gateway is an adsl modem.Is posible to do this setup with the setup wizard for the uc540 in the i...
lzuniga99 by Level 1
  • 3901 Views
  • 9 replies
My ATA232D is connected to Ubiquity Edgerouter X.  I have other SIP phones on my network that can send and receive calls without issue.  Since a few days I can not connect to incoming calls. Outgoing calls are still possible. I have no changes to the...
alanauld by Level 1
  • 1449 Views
  • 4 replies
There is a way to connect CP-8961(last sip firmware) to SPA-3102 without pbx/asteris/any other server side sip)? I configured spa PSTN line for IP dialing so I can call in/out on PSTN line with softphone. Now I want to connect my CP-8961 to spa (over...
psyafter by Level 1
  • 1438 Views
  • 0 replies
Hello,I,ve problems with CCA 2.2(5) making a backup of the config and installing new software. So I found the nice articel "CCA Prerequisites for UC500 connection - check list" and tried it. I'm stuck at check routing CUE->PC. I can't ping the defaul...
Hi everyone,   I'm using a Cisco SPA 112 for a few months now without any problems. I recently changed my ISP and now I can't call one (quite usual) specific telephone number. Everything else works perfectly fine. I can call all other numbers I tried...
Hi There   I am trying to set the physical hold key on a spa514g to map to a PSK that I have defined.    I have followed the instructions on this page however it doesn't change the physical hold key.   https://www.cisco.com/c/en/us/td/docs/voice_ip_c...
PDANZ by Level 1
  • 1733 Views
  • 7 replies
We have two UC540s. Both devices are configured with identical dial-peers for voice mail.   When a call from UC540-A is made to a DN on UC540-B, if it goes unanswered and is set to forward to the voice mail pilot, the call is directed to the dial-pee...
R M by Level 1
  • 1149 Views
  • 4 replies
I'm replacing my relative's ISP provided all-in-one cable modem/wireless router/VoIP with their own cable modem and firewall/router (separate devices).  I've purchased a Cisco SPA 112 phone adapter so they can keep their VoIP as well.  The ISP is tel...
i have a netgear ac1200 and a cisco spa 112, on some but not all calls there is a delay when i answer the phone sometime up to 30 seconds before i can hear the other person and they can hear me, i miss quite a few of these calls because the caller pu...
