HiI have several phones , SPA 525G , SPA 508G and a 509GAll are getting vlan 100 and ip address from UC 320 Pool DHCP Voice server, but it seems SPA 509 is not provisioned. I has updated firmware to 7.47v21 and i made several factory resets with no l...
I have pressed several times and it seems to do not restore password as i could gain access to admin device. I was trying to inspect default dialplan, as i could not call outside with 0 as phone shows me "Number not valid".
Hi everybody,I'm going to setup my AA with pre-registered wav audio files.After a lot of trouble I've found the correct convertion format for the audio files (*) and no I'm able to upload it from the AA gui (Call Handling --> Auto Attendant --> Promp...
Hi, im using now succesfully VoIP phones SPA 921/922/941/942 and this works well. I build custom dialplan with #4xx number that is command for my pbx software. Now i buyed few 502g and when im trying to call number #4xx with the same dial plan i ...
Hi All,It has been an interesting week, with the release of CCA 3.1, SWP-8.2 and OM 2.0 all released at the same time, we certainly were spoilt.Well over the last couple of days and on the weekend, I spent some time reviewing OM version 2.0 just rece...
Hello everyone,I'm planning on setting up a UC320W for use with several SPA 525G2 phones. We currently have phone service through Vonage (2 lines, but will have 5 soon). Is it possible to run the Vonage service straight from the UC320W? Has anyone tr...
Hi Cisco Team,Firstly let me just congratulate you on the release of CCA 3.1 and what a FINE release it is So let the fun begin...Was bored on the weekend so I decided to give this thing a good once over, and finished it of this morning by checking i...
Hi guys,is 2 days trying to get my SPA3102 but I can not. Let me explain better my situation. I bought an SPA3102, my requirement is to remote my telecom phone line to use it even in my home is equipped with a secondary connection to the Internet. I ...
Hi,Can the SPA525G2 please allow 1 call appearance per line (instead of minimum 2)?This then replicates the behavior of all the other phones in the 5xx line.It is very disconcerting to users to have multiple calls come in on the same line key.Thanks....
I'm looking for a way for the IP Communicator to be used when traveling and assume the identy of the persons office phone including extensin, VM, etc. Is Extension Mobility the way to do that? The Office Phone will be a SPA504 or 525G2.
HINot sre if this is correct, im using voice only topology, and i have 3 spa phones plugged directly into the uc320w, the dhcp for Data is on a windows server, now when i have a look at the network settings in the phone i see that the vlan id is 1, s...
Hi,Firstly i apologise if a) this question has already been asked b) this is the wrong forum. I've asked it here because i just can't find the answer !!!Anyway, my thanks in advance for your advice on this.We have a UC560 system. The UC has a SIP con...
Hi all,Trying to setup my very first UC540. I have a problem with the voice mail and AutoAttendant. When I dial it it says enter my extension followed by "pound sign" I enter this and it just keeps asking "are you there?"I have all the latest versi...
Can anyone assist me in getting CCA to find my UC540wI think I may need to change the ip address of the telephone system from a 172 address to a 10.15 address and not sure of the implications or whether this will enable CCA to work.Can anyone advise?
