How to make a cisco 962 respect it's date and time server settings?<Time_Zone group="Regional/Miscellaneous">GMT-08:00</Time_Zone><Time_Offset__HH_mm_ group="Regional/Miscellaneous"/><Daylight_Saving_Time_Rule group="Regional/Miscellaneous">start=3/2...
Hi all,I have a UC540 running on ios 15 with CME 8.1.I set up an additional Data VLAN which only has to get direct access to the internet through the configured dailer0 interface, which is also used by the default data VLAN.I also defined a DHCP-Scop...
I am trying to use traffic-export on a uc500 to troubleshoot some SIP issues. Using traffic-export in capture mode seems to work well -- but your limited by the amount of memory in the box; I would like to do some long-term logging.To do this I set i...
We have successfully set up Fax to Email using a UC540-FXO solution using just the CCA. We will have a customer with a UC560-T1E1-K9 and they will be deciding whether to receive faxes using a PRI/DID or FXO line. Does the CCA support the fax to email...
Hi!!!Yes,this morning on the phone any number entered will be cut to 3 digits (on display) and then get a busy signal. I tried to reboot, nothing ...I type 001555555... After pressing the dial for a moment the display shows the full number and immedi...
We have a a UC320 and receive our SIP trunks from Bandwidth.com. The system is configured with 10 digit dialing and 3 digit extensions. In order to get an outside line we must dial a 9 and then the 10 digit phoane number. Our old system allowed us...
Hi,I write here this question, since I was told to do so (https://supportforums.cisco.com/message/3354884#3354884)I am trying to do a hotline System with only two IP Phones in the same VLAN. I am not allowed to use a call manager. Therefore, both pho...
I imported about 70 client phone numbers into our UC320 directory list. We are using the SPA504G phones and trying to access these client numbers. When we select the softkey "dir" there are choices for which directory appear on the screen. After s...
Hi guysI am desperately trying to connect my SPA942 phone with my phone provider Cablecom in Switzerland. I am connected to their network via a Thomson Router TWG870 and using their service for internet, cable tv and analog phone - everything works p...
There is now a 3rd party iPhone Sip client that works successfully with the UC500. It does have the Apple imposed limitations on Use over 3G and not being able to run as a background process on the iphone, but other than that it works pretty well.Fo...
I setup a remote office with 4 SPA509 Phones using a an SR-520 VPN to a UC540. When users call extensions from remote site or to remote site they sometimes experience one way audio. I did setup the phones at the remote site to be Teleworkers and th...
I have a demo uc320w and SPA525g phones.My first client says that they do not need color displays. So they just want a 8 line phone.I cannot figure out what the difference is between an SPA501g and a SPA508g. They both have 8 lines, the pictures lo...
HiMy Client have a UC560 and they are inplementing and exchange server which is pointed to an external hosted Spam filtering ccompany (McAfee), the client wants only his server to accept mail from the hosted source which they have provide a range of ...
Hi!I have two device SPA3102. Connection type:ATS---SPA3102---Switch---Mediaconverter------Mediaconverter---Swith---SPA3102---PhoneAll good work, but еach 15 minutes on phone there transits one call. Tell to me please whence transits this call.Debug ...
