I have a client who wants to add four phones to a UC520. Here is the output from the 'show platform software license'#show platform software licenseUpgrade license : uc500-16u-upgradeLicense UDI : UC520W-8U-4FXO-K9 :FHK1...
Hi All,Just a simple question. Configuring an Auto Attendant, how do I go about making it so if no input is selected, it auto forwards to an extension after a certian period of time?I'm using the CCA 2.0.1 (1).
So the Cisco 7900 series phones advertise wideband audio a great feature, and I believe the SPA phones support it as well, but it seems the UC560 is defaulted to use G711ulaw. Since we're connected to the PSTN via a PRI, I'm guessing it won't do muc...
So I configured a SIP trunk from les.net for testing, Trunk works, can place and recieve calls...However if I disconnect the WAN port cable and wait a min and plug the cable back in, the system reboots along with all phonesalso for a office with a p...
Hi all, is it supported srtp on ip phones on UC520 ?If o is there a quick guide to do it?I checked on the net and saw the security guide for CME but some commands are not accepted.Can you help?Best Regards,Jose Carlos
Hi all,I have read that you can add a flash softkey to IP sets, but do not see where/ how to add it, under users / extensions.If someone could tell me, I would appreciate it!As well, does anyone know if you can add a feature access code or STcapp FAC...
I have a about 15 floating extensions setup for users that want their calls to directly to their cell phone, but some of these users want to have a physical phone. Is there any easy way of turining a floating extension into a "regular" desk phone ex...
HiI have customer that we have implemented uc560 but he has weird requirement .he want the auto-attendant in business hours to transfer directly to receptionist and in after business hours he wants to play message and press 1 for x . I can not do thi...
HiOur client has 8 SPA504G Phones connected to 2 SR300-28G which is connected to the UC540 (Version 8.1) Via the expansion port. The problem the client is having is that sometimes the users are unable to transfer phone calls between the phones (the p...
We have a client that has 3 different physical phones with 3 different extensions that he uses throughout the day. His secretary was wondering if there was a way to setup a watch line on her expansion module that could tell her if any of those phone...
I have a UC540 with an internet connection/firewall and 5 SPA phones on the inside running fine. I want to configure a phone that can be used at a remote site over an internet connection and have an extension on the system. It would be one that you c...
This seems to happen a lot:Change a config on a phone button, or add a user to a paging greop, hit apply config, you get this message with a greyed out "Apply All Change" button;Your changes have not been applied to the device.You can continue to mak...
Can the UC500 series (v8.1.0 code bundle with CCA 3.0) be configured in such a manner as to use TLS to authenticate to a foreign mail host in order to send voicemail notification rather than just standard SMTP? If so, where may such configuration st...
