Please advise the best headset for the SPA phones we have sold Plantronics C555 with the lifter and cusotmers are not happy with them on the SPA phones, please suggest a goodwireless headset.Thanks
HiI want to create inter company extention on UC560 for a customer. like1 (NY), 2 (LA), 3 (LO) and then the specific person’s extensions on SIPcan anyone advice me on this. how to do this on CLI and CCA. because currenly we use CLI and planning to re...
Hi all,I'm having issues with a few SPA504G.They are rebooting periodically every hour, and syslog says:Reboot reason:C2000I've looked at all the reboot codes and could not find any information.It happens with FW 7.4.6 and 7.4.8Any ideas?Thanks!!
Hello,I'm considering the SPA2102 for deployment, but need support for TLS/sRTP.I've noticed a few postings about non standard key exchanges, and the requirement to obtain a certificate generator for use with the device.Can anybody offer advice on th...
Why am I seeing this message when opening "Phone VPN Setup Wizard"?"no eligable SPA 525 phones are available"There IS a SPA525G2 phone connected to the UC540 and it has an extension configured.We want to use the 525 as a remote teleworker.I am not fi...
Question. If the system requires a "9" to make an outbound call how is it set up to automaticallyadd the "9" when choosing a "Missed" or "Received" calls under the "directories" button?The client goes to directories, chooses a missed call number, pr...
Hello! On my UC560 recently upgraded to 8.0.3 I have a general delivery mailbox that messages are left in, and notification is turned on. The first alert is an email message to oncall@email.com, and if that message isn't retrieved in 45 minutes, an...
Hi,Since I implemented the SPA9000 it is impossible to dial the saved directory numbers in format example +4989xxxxxxx (+49=countrycode 89=areacode xxxxxxx=phone number).As long I used our SPA9xx as single phones each with its own voip provider numbe...
The CCA instructions say(warning comes up in telephony wizard, ie a new install)."You must connect the UC560 to the SA500 begore continuing..."OK fine.Connect WAN port on UC560 to a LAN spare port on the SA 520.Configute smartport as access points (t...
On the Cisco SPA5xxx phones (ie: SPA509g).....When an extension on a BLF dials a number, and the remote phone rings, the BLF for that extension flashes red.For example, extension 100 dials (111) 222-3333. Phone rings at (111) 222-3333. BLF light for ...
After upgrading to firmware version 7.4.7, the SPA-504G phone disconnects the existing call when a speeddial button is pressed. This problem occurs with 7.4.7, 7.4.6, 7.4.4, but does NOT occur in 7.4.3. This problem occurs with both fnc=blf+sd and ...
We're using a new SP that uses in-band dtmf for incoming calls. DTMF in outgoing calls works fine out-of-the-box but incoming to the AA doesn't.Does the UC500 handle in-band and if so how do one configure it?Best regardsMarkus
Hi expert,I have UC320W, I have 2 connection SIP and PSTN line for outbound call. the problem is Can I choose the outgoing call manually.exampleif press 9 the otubound via PSTNor if we press 8 the outbound via SIPThanks
Hello, I can not enter the sub-menu 18 Language on my new SPA508-phones with neither firmware 7.4.3a nor 7.4.8. I want to change to language to Swedish and acording to this page: http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps1049...
