Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
I have an issue with the SPA 122 fax capability.  SPA 122 device is register on UCM and making a call without any issues.  When i tried to send fax, connection was made with other end device but I'm getting failed massage while trying to send a docum...
Hi community , I have an ATA SPA122 connected to my modem router ..i'm not getting any audio. below what i have done so far :Network configuration :internet |MOdem Router (Hub 2000) - SagemCom fast 5250|SPA 122 (via internet : blue connection)|phone ...
I have bought a new Cisco Spa 8000 gateway and have update firmware to 6.1.12 and have 8 sip lines registered and working,the issue i have is incoming calls only ring in once and when first sip is busy it gives me busy tone,i want it to hunt to the o...
philip11 by Level 1
  • 1387 Views
  • 0 replies
I'm having issue registering a 9971 phone on a UC520 running CME 8.6Here are the relevant configs -voice register global mode cme source-address 10.1.1.1 port 5060 max-dn 224 max-pool 56 load 9971 sip9971.9-2-2 load 7971 term71.default authenticate r...
We have a UC540 in production.  It has been working perfectly for the last couple of years.  We added 3 phones last week that booted normally and we were able to make calls from.  Over the weekend all phones lost registration with the UC and none wil...
Plantronics Voyagre Pro UC V2 (BT300) was paired with my Cicso 525G2 until we did a factory reset on the 525G2 yesterday. The 525G2 is able to find the BT headset but will not accept the pin code 0000 hence unable to "connect" the 2.  Do we need to c...
peter by Level 1
  • 1008 Views
  • 0 replies
Hello everyone,is it possible to register SPA112 with CUCM 8.6 nodes using SRV records at all?When I indicate IP address of the publisher, SPA112 gets successfully registered. However, when I configure SRV records on my DNS server for two callmanager...
Resolved! SPA 3000 Problem
Hello i recently got myself a SPA3000, but i seem to have a problem with it as i can't get it to work. When i plug the power adapter in, lights start flashing, all 4 of them,and i hear a couple of clicks coming from inside of the ATA, then after 5 se...
dragonoid by Level 1
  • 3131 Views
  • 2 replies
I have 2 different phone models (SPA504G & SPA525G) in use, both on firmware 7.6.2a. My goal is to send text messages with Asterisk (MessageSend) to the phones.This works without any issues, but I also want to clear the messages on the phones (remote...
I have installed the SPA112 ATA Device, upgraded the FirmWare, and carried out the "Quick Setup", and created a SIP Line Extension and DDI in Avaya IP Office.   I now get a UK dialing tone, but when I try to dial out (to any number), from this Device...
shergill1 by Level 1
  • 1718 Views
  • 0 replies
I have following issue and could not find any hint on the net: I want to enable FAT (Call forward all service enabled) and FAF (Call forward all service disabled)'via softkey on my SPA5xxG phones, sending the entered number to my PBX AND let the theb...
I have an SPA112 running 1.4.1 (002) Oct 26 2015, and I've got a profile gzipped and encrypted using openssl and served via HTTP. If I encrypt the profile on up-to-date Ubuntu 16.04, OpenSSL 1.0.2g 1 Mar 2016, the ATA can decrypt the file, and the AT...
