we have a Cisco UC320W (firmware 2.3.2(6)) and some Cisco SPA303 (software 7.5.2(u3)).
We have this issue: we have assigned a phone to a new user, so we have changed the name of that user on the "UC320W configuration utility" (under "Users/P...
I have been looking and trying for days to get the UC560 to send VM to email at Office 365 hosted Exchange.
I have read countless forums and documents and nothing is working.
I have tried all the options in this MS document, https://support.office....
Hi, at the company I work at, we use a UC520. Voicemail used to work, but awhile ago a SIP Trunk was added and the voicemail stopped working. I was not the one who added the SIP Trunk, so I'm not sure if anything else was changed while that happened....
Hello Voice Experts & Engineers,I`m currently required to design a small business IP Phone Solution. The estimated user is 122 people.Here are some of the requirements & details
There are 2 site (61 user at each site)The 2 site have to be intergrated...
We recently connected a new client with 30 509G phones and two multicast page groups, configured as follows.
pggrp=224.168.168.168:34560;name=All;num=800;listen=yes;pggrp=224.168.168.168:34561;name=Service;num=801;listen=yes;
While this w...
I'm in an older condo and the door is wired directly into the apartment. If I put an analog phone on the lines in the house, it rings and we can talk to the person at the door. When I plugged the SPA112 into the lines in the house the buzzer doesn'...
Hi.
I get one trouble with Cisco SPA232D.
I have 2 Cisco SPA232D.
The system is working since many months without problem, but now the line LED is off on both Adapter.
When I test the incoming line with a normal phone, the phone are working.
What can...
I'm trying to configure my recently purchased Cisco SPA112 ATA, paired with a D-Link AC1750 modem Router, to use the TPG VOIP Service.
I've had a number of telephone conversations with TPG Support, but they seem to have very limited knowledge of the ...
Hi, I'm just wondering what is the latest version of CCA that can be used to config a UC540? .... 3.1, 3.2, or 3.3? I don't want to make assumptions in my greenness and appreciate any feedback.
Hi Experts,
Someone suggested to use SPA112 in a place of ATA186/187 as i was not able to find these in the market. I bought SPA112 and when about to set this up, i come to know there is no Ethernet interface but only the Internet port. The manual gu...
I use the SPA 122 which has the following specs:
Version 1.4.1 (002) Model: SPA122, LAN, 2 FXS Product ID: SPA122 Hardware Version: 1.0.0 Firmware Version: 1.4.1 (002) Oct 26 2015
Problem:
1- The software gets corrupted again every few days! 2- Wh...
I recently bought a Cisco SPA525G2, hoping to use its Bluetooth feature to connect to my Bluetooth speaker and microphone. But it turns out this Cicso phone cannot find my Bluetooth speaker. My speaker is a new Logitech P710e model, and it works fine...
We are using the Cisco Smart Call Connector Manager along with the Operator panel. Its version is 2.02.007 . The call router is a UC560 model. Recently I have noticed that the operator panel is not showing updated user information. This is obviously...
