All,All voice mail rom either internal or external callers are off by 7 hours.We are configured for PST.Please advise.It seems like CUE or CME may by the culprit.
I have an asterisk trixbox ce system and some phone calls are not disconnecting which I beleive are also causing our phone calls to drop.Software Version:6.1.3(a)I have contacted trixbox support and they said the system sends the phone a BYE message,...
Hello again...This is a new deployment of UC540 and a ESW 24 port POE switch.Our new ESW 24 port POE is stating the status of all up ports are HALF duplex. All the ports have been given a smartport role that is appropriate for its current usage.Any ...
Trying to decipher a datahseet and hoped you might have some insight. Call Manager has listed that "Auto attendant-Bundled with Cisco CallManager via the Extended Services CD." but I have not been able to confirm if that CD comes with it or is se...
Hi,The company where I work is going to buy a large number of IP phones SPA525G and I want to know if it is possible to configure massively? If so, the configuration file is XML? My company does not use CCM.Thanks
Hi AllIs extension mobility supported on the UC500 platform? If this is possible can someone please provided out of band configuration guidelines to implement it.Steve
Hello!Just had a question regarding an external DHCP server for a UC 540. I have added the "IP helper-address" command to "Interface BVI 1". Everything works ok, my computers get a dhcp address but as soon as I try pinging from CUE out to th...
Dear Sir or Madam,We have an problem with BLF.The spa504g is not learning the Record-Route within our 200 OK (for the first Subscribe). It must set its route set (Route header) to match the list of URIs in the Record-Route header sent in the response...
I have an spa525g with the spa500s sidecar. The sidecar buttons are working for direct dial and status, however when I try to do a blind transfer for a button the call fails. If I do a blind transfer and enter the 3 digit extension it works fine. ...
Hi folks,I want to use Cisco SPA525G with leading SIP based Internet Telephony Service Provider (ITSP) which supports calling to US numbers and should also support most of the features of Cisco SPA525G.Please suggest me the name of ITSP.Thanks a lot,...
Our company has a single UC520-48U, and we foresee the need for expansion to about 120 ports. We use DID, so is there any way to implement multiple UC520s and transfer and route calls between the UC520s? I've seen a tunneling solution that claims to ...
Hi Guys,Just want to check in with you to see how far away you are from releasing the software update packs and the new version of CCA.According to the software road map release matrix there was supposed to be a release in July and then another in Au...
All,This is a new deployment of a UC 540. We are trying to upgrade the current image to the 8.0.2 and get the attached error when processing the CUE upgrade portion. It fails around mid-way of the phone load upgrade #2 to CUE.A few notes:The 521_52...
