Hello,Can CCA front panel view be made to update port status in real time? If not is there a way to get real time port status information from the ESW or CE range of switches as the command line is unavailable.Thanks in advance.
I am trying to create a script on a UC540 that we can take offline and make changes to. We have been able to create this from within CCA – Auto Attendant but am not able to locate the script for download, after building changes into it. Is it saving...
From the auto attendant, I can dial by extension and that works fine. But does it only work for a user's "main" primary extension?I have users set up with multiple normal extensions, but the dial by extension only seems to work for the main ones. I...
Hi,I am trying to get the PVC2300 to play nice with a UC520 (7.1.3), and I've uploaded 1.1.2.6 to the camera. I can see it via Bonjour in CCA, but when I go into the Video Monitor Setup Wizard it says: No Cisco 2300 series camera found.I am using a u...
Hi all,UC540 with auto-attendant. AA main menu offers to dial your parties extension if you know the number or to choose 8 for french menu or 9 for english menu. If you select 8 or 9, it offers you to choose for Customer Service press 5 or Shipping p...
I have SPA9000 with 2 SPA400. It purchased recently. SPA400 configure for voice and another SPA400 for existing 4 PSTN line. I connected PSTN line to the RJ11 port of SPA400. I do not see the LED green light. I cannot make outside PSTN call. Do I nee...
Hi,I have a customer who has a Uc520 system 48 users, what he wants to do is to Dedicate a group of PSTN Lines for a group of Extensions, that means for example:Extensions (201,202,203) will be only allowd to use (FXO ports 1,2) and extensions (204,2...
i have configure vpn router 877 to uc500. i have done everthing accroding to vpn process.final it not ping if u have any details plz send with full information as your friend waiting for ur reply
Hello,I had no success provisioning the router configuration with the firmware v2.00.05 with the same XML file I provision the version v1.01.00. The voice part is configured (<flat-profile>), not the router part (<router-configuration>).Syslog shows ...
I have a new SPA400 that I've had running for about two weeks. This morning it started rebooting, and I have no indication as to why. Watching the lights on the front of it, power is on solid, ethernet is flashing periodically, all four line lights a...
I'm trying to get the outgoing Caller-ID Name to work with Skype for SIP. I changed the pstn-to-sip under sip-ua, but it still shows Private when I place an outbound call. I'm want the company name to show. It worked with another SIP provider so I...
Hello,I'm looking for French Voicemail Prompts for my Linksys SPA400. I have contacted the reseller (Amazon.com) that I have purchased the device with but they are unwilling to help me. So if Cisco could help me obtain it, that would be nice.Thank yo...
Has anyone else had issues with RSS feeds on the SPA-962 (6.1.5(a)) ?The first 1 or 2 feeds I select after the phone boots come up OK but then I can't switch to another feed - it just hangs at 'Updating news feed data...'. It doesn't seem to be a pro...
When dialing digits while in a call (e.g. connected to an IVR) the phone sends DTMF but the dialed digits are not shown on the display of the phone.Is there a way to enable that function?
we just bought spa8800 series gateway 4fxs with 4 fxo port. And found there is no option to set NAT mapping enable "No" however does allow to set for Phone 1 but for other lines its "Yes" by default and does not allow to set.We did try to disable by ...
