Hi there;I have the spa9000 and the spa400, but i have a problem with incoming call´s, when the caller hang up the call stay in AA for hours.i need to delete the call from the SAP9000 web server to release the line.so any help please?Best regards.
Nothing else to add
Reasons why support for NSS devices in CCA would be useful:CCA 2.2 already supports the Cisco Small Business PVC2300 and WVC2300 video surveillance cameras, and the Cisco Small Business PVC2300 and WVC2300 video surveillance cameras have been designe...
Where's the download? Is Cisco under maintenance? All I'm getting to download is a PDF document. Nice but it's not going to do the job. Please help.Stephanie Heidemann
Hello. I have a question about using Netgear switches at a remote location.The system will be a UC560 at the main office.An SA520-K9 at the remote office and 5 SPA504G phones.The remote office has Netgear switches (not sure of Model numbers) already...
I have recently installed my first UC500 system(UC540). All of the programming was done with CCA or the Web GUI. After setting up the park feature I realized that there is no park recall configuration in CCA nor the Web GUI.After calling support and ...
I was wondering what the maximum amount of phones that can be supported in a page group? I assumed it was equivalent to the licensing of hte UC but I was asked so now I would really like to know.Thanks in advance,Bob James
Hi Team,The Smart CallConnector Operator should be FCS in mid January regarding this thread: https://www.myciscocommunity.com/message/29356, but I still can not find it from the Australia Wholesale Price List.So, my questions are:1. What is the FCS t...
Does anyone know where I can find a customer facing brochure on the new Small Business Pro Rapid Replacement?
Is there any way to turn off the beep when you push the live record button? In Wisconsin, only one party has to know the call is being recorded.
Hi All,Looking for some advice on the following Problem:Cisco 7930 Phones periodically drop out of the Hunt-GroupPhones then ResetPhones Re-Register but in ITS modeNo longer able to join a Hunt GroupCan Make calls, but can only receive calls pointed ...
We are running a 48 user UC520. We are having an interesting issue. We have our voicemail set for the zero out option. When a caller presses that option it will be transferred to our voicemail. The caller id on the other end of the call has a hyb...
I have found that in configuring the UC500s, if I make a change to the Internet connection (even the SA500s on the WAN side of the UC500s), that it breaks the connection to the SIP trunk (which is not a surprise). Is the UC500 set to retry the SIP r...
Hi,I understand that the limitations is due to the number of VPN tunnels supported by the device. But if the tunnels are created with another device and the UC500 acts as a PBX-IP. it´s possible connect more than 5 UC500 trough IP trunks?Ramses Leal
Does anyone know of a Cisco recommended or thris party shoulder rest for a SPA 504 phone?Does Cisco even make such a thing? The customer is a little old school and doesn't want a headset.Thx,Stacy
