Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
I have https enabled on my UC520, and there are self-signed certificates in both the UC520 and Cue.When I log in through CUE Web admin, to configure Integrated Messaging, I get an error when trying to enable SSL for the connection security.The error ...
Resolved! uc540
Hi,Just saw an article on the uc500.com page about the uc540. Is this only a different software or is it just the software pack? I saw that SSL VPN was one of the new features, is this going to be availiable on the 520??My question:What´s the differe...
Hello,I've enabled SSL-VPN on the UC520 with CCA 2.1 and everything works fine with the exception that the users that VPN in do not have any internet access. After some research I've notice that the only route the anyconnect client has is the default...
Hi,We are using SPA-841 model SIPURA phones in our office. Today I have seen in our office that, one of the IP phone was showing S.O.S Phone in Receovery mode. Actually we didn't done any firmware updations as per well knowledge. Our current software...
I just tried updating the software, both the IOS and the CUE for a UC520 router using the CCA 2.0.1.   It formatted the flash, then failed to install the IOS or the CUE claiming I had a FTP or TFTP server running.  This laptop has never had/ or run a...
I am completely fed up with having to deal with the lack of support on the SBCS products.  I don't have the time or patience for a bulletin board.  Any time I have ever called the TAC for support the engineers refuse to use CCA and then consequently,...
dcomdan by Level 1
  • 3370 Views
  • 5 replies
Hello all,I'm having difficulty with this feature. I have a Linksys SPA 3102, with both ports registered with my SIP provider. I've enabled PSTN-To-VOIP. I would like to achieve the following.1.     If I call my PSTN number from my mobile, I should b...
I would like to disable DHCP on the UC520 but I dont see any options to turn it off, it appears I can just remove the scope but then the phones hang on ftp download. Are than any option that are required on the Microsoft DHCP Server to let the phones...
acole10000 by Level 1
  • 2940 Views
  • 10 replies
