02-11-2013 01:23 AM - edited 03-21-2019 06:58 AM
Hi, we intend to change our UC solution from CME running on a 2901 to BE3K. As we are a small organization, we are using a BRI interface to connect to the public phone network. Our plan is to deploy BE3K and use the 2901 as a gateway to PSTN for BE3K. However, i couldn't find any reference that this represents a supported setup. Is it supported, and if yes, how do we need to setup BE3K and the ISR?
Thanks & best regards
Frank.
02-11-2013 01:40 AM
Hi Frank,
This is certainly possible (SIP trunk to 2901 configured as a PSTN gateway).
We will be providing additional guidance on how to deploy this solution with our next BE3000 release in late Spring.
Andy
02-11-2013 03:11 AM
Thanks for your reply on this Andy..!
However i can't find this in the admin guide under "gateways":
Does "connection type "refer to the connection from the 2901 to the PSTN? If yes, i would regard BRI connection as being unsupported for 8.6.4. Or did i miss something?
Could you give me any reference to a document how to configure BE3K and 2901 with a BRI interface *before* late spring? ;-)
Cheers Frank.
02-11-2013 07:31 AM
Frank,
Be3K to 2901 BRI is currently not supported, but it should "technically" work when connected through a SIP trunk. We are not focusing on the integration as this is not exactly financially economical solution unless you already have a 2901. However we are verifying the integration and may release documents supporting the integration in the future, for deployment where 2901 is already part of the solution.
Navin
