BE6M-M4-K9= & R-CBE6K-K9 License Count in CCW
Hello
With respect to BE6000 ordering guide at http://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/business-edition-6000/guide-c07-717328.pdf
I need BE600M system so selected BE6M-M4-K9 product code
License to be added through R-CBE6K-K9
Now whenever I configure more than 150 licenses the configurator says that "the maximum of allowed licenses is 150".
Max 150 Licenses is the limit for the BE6S (small) system.
Where did I go wrong?
How can I get max 1000 licenses for the BE6K-M4-K9 system?
Fred
5 Replies 5
Jaime Valencia
If you're a partner, get in touch with pre-sales so they can assist you with this.
java
if this helps, please rate
praphans1
Hi Fred,
Yes, BE6K-S support 150 user in 1 server, for BE6K medium density which can support 1000 users, you can use this BE6M-M4-K9= for BOM generation, then you  can select type of power, so you will finish in BE6K-M part
Next, you go to R-CBE6K-K9, and click option then you can select the version of software in require software version and then go to license starter bundle, this is cisco promotion which provide 25 licenses in the package. so if you need 1000 lic, you can select starter licenses and go to add more user, select the type of license that you want to purchase, so this case, you have to fill 975 lic.
Praphan
You can see the BOM as attached file
[object Object]
Hello Praphan
Thank you very much for your detailed answer.
I mixed up the software versions not selecting the one for 1000 licenses.
"Once you're committing an error you're prone to repeat it" so I did not find the flaw until I saw your repsonse.
Fred
OK, If you mix, so you just change the server, you may use ucs instead of BE6K or use BE7K, the maximum may be 1000.
Please bear in mind though that licenses purchased through R-CBE6K-K9 are only for use with BE6000 hardware (not UCS or BE7000).
Andy
