Block incoming calls based on calling number.
Salnikov Andrey
Hello All,
I have Cisco UC500 as voice gateway for Cisco CUCM. I need to block a few incoming numbers based on calling number. I have FXO voice ports with connection plar to 588 and VOIP dial peer with destination patter 5.. (to CUCM extensions). When I apply rule for the dial peer translation rule does not work but calling number comes with correct format.
My config is:
voice translation-rule 10
rule 1 reject /6XXXXXX3/
rule 15 reject /9XXXXXX9/
voice translation-profile CALLBLOCK
translate calling 10
voice-port 0/1/0
disc_pi_off
cptone SG
timeouts interdigit 3
connection plar opx 588
caller-id enable
dial-peer voice 555 voip
call-block translation-profile incoming CALLBLOCK
call-block disconnect-cause incoming call-reject
preference 1
destination-pattern 5..
voice-class codec 1
session target ipv4:192.168.52.250
dtmf-relay h245-alphanumeric
no vad
On debug I see that this Dial Peer is in use and incoming number in correct format but translation rule just does not work.
Jan 28 01:06:58.359: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
Jan 28 01:07:00.312: //-1/533D512BB256/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=9XXXXXX9
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=588
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 28 01:07:00.312: //-1/533D512BB256/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x86F16B50, Call Info(
   Calling Number=9XXXXXX9,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=588(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
   Interface Type=2, Protocol=0
Jan 28 01:07:00.312: //-1/533D512BB256/CCAPI/ccCheckClipClir:
   In: Calling Number=9XXXXXX9(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Calling Party Number Is User Provided
   Out: Calling Number=9XXXXXX9(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jan 28 01:07:00.312: //170918/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=1
Jan 28 01:07:00.312: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 28 01:07:00.312: :cc_get_feature_vsa malloc success
Jan 28 01:07:00.312:  cc_get_feature_vsa count is 1
Jan 28 01:07:00.312: :FEATURE_VSA attributes are: feature_name:0,feature_time:2290371160,feature_id:27144
Jan 28 01:07:00.312: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Jan 28 01:07:00.312:  call_init_entry calle is 886F83E8,callid is 170918
Jan 28 01:07:00.312: //170918/533D512BB256/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=170918
Jan 28 01:07:00.312: //170918/533D512BB256/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=9XXXXXX9(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=588(TON=Unknown, NPI=Unknown))
Jan 28 01:07:00.316: //170918/533D512BB256/CCAPI/cc_process_call_setup_ind:
   Event=0x86EB8C28
Jan 28 01:07:00.316: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=588, Call Transfer Consult Id=
Jan 28 01:07:00.316: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
Jan 28 01:07:00.316: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
Jan 28 01:07:00.316: Comparing SSOpCode; 0x50 and 0x0
Jan 28 01:07:00.316: Comparing SSOpCode; 0x12 and 0x0
   Try with the demoted called number 588
   No Matching Node
Jan 28 01:07:00.316: //-1/xxxxxxxxxxxx/CCAPI/ccAppInitializePID:
   Application Process Name=_ManagedAppProcess_Default, Application Process Id=93, Application Handle=0x88704BCC
Jan 28 01:07:00.316: //170918/533D512BB256/CCAPI/ccCallSetContext:
   Context=0x8871D458
Jan 28 01:07:00.320: //170918/533D512BB256/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 170918 with tag 10 to app "_ManagedAppProcess_Default"
Jan 28 01:07:00.320: //-1/xxxxxxxxxxxx/CCAPI/ccAppInitialize:
   Application Name=_ManagedAppProcess_Default, Application Process Id=93, Application Handle=0x888B1030
Jan 28 01:07:00.320: //170918/533D512BB256/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Jan 28 01:07:00.324: //170918/533D512BB256/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=555, Params=0x887259E0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jan 28 01:07:00.324: //170918/533D512BB256/CCAPI/ccCheckClipClir:
   Destination Pattern=5.., Called Number=588, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=533D512B-86EF-11E3-B256-AB2264B56785, Outgoing Dial-peer=555
Jan 28 01:07:00.324: //170918/533D512BB256/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=9XXXXXX9
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=588
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jan 28 01:07:00.324: //170918/533D512BB256/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x86194F68, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=9XXXXXX9,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=588(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=555, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jan 28 01:07:00.324: //170919/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
Jan 28 01:07:00.324: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 28 01:07:00.324: :cc_get_feature_vsa malloc success
Jan 28 01:07:00.324:  cc_get_feature_vsa count is 2
Jan 28 01:07:00.324: :FEATURE_VSA attributes are: feature_name:0,feature_time:2290370936,feature_id:27145
Jan 28 01:07:00.324: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Jan 28 01:07:00.324:  call_init_entry calle is 886F48B0,callid is 170919
Jan 28 01:07:00.324: //170918/533D512BB256/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=170918, Bindee Call Id=170919
Jan 28 01:07:00.324: //170919/533D512BB256/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=170919
Jan 28 01:07:00.324: //170919/533D512BB256/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jan 28 01:07:00.324: //170918/533D512BB256/CCAPI/ccCallSetupRequest:exit@2521
Jan 28 01:07:00.324: //170919/533D512BB256/CCAPI/ccCallSetContext:
   Context=0x88725990
Jan 28 01:07:00.324: //170918/533D512BB256/CCAPI/ccSaveDialpeerTag:
Jan 28 01:07:00.324: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
   data_mode=0x10082
Jan 28 01:07:00.328: //170919/533D512BB256/CCAPI/cc_incr_if_call_volume:
   Remote IP Address=192.168.52.250, Hwidb=Vlan2
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
Jan 28 01:07:00.340: //170919/533D512BB256/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Jan 28 01:07:00.340: //170919/533D512BB256/CCAPI/cc_api_call_proceeding:
   Interface=0x86194F68, Progress Indication=NULL(0)
Jan 28 01:07:00.340: //170919/533D512BB256/CCAPI/cc_api_call_proceeding:exit@7010
Jan 28 01:07:00.348: //170919/533D512BB256/CCAPI/cc_api_set_called_ccm_detected:
Jan 28 01:07:00.348: //170919/533D512BB256/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Jan 28 01:07:00.348: //170919/533D512BB256/CCAPI/cc_api_call_alert:
   Interface=0x86194F68, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jan 28 01:07:00.352: //170918/533D512BB256/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jan 28 01:07:00.540: //170919/533D512BB256/CCAPI/cc_api_set_called_ccm_detected:
Jan 28 01:07:00.540: //170919/533D512BB256/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x86194F68, Call Id=170919
Jan 28 01:07:00.540: //170919/533D512BB256/CCAPI/cc_api_call_notify:exit@7951
Jan 28 01:07:00.540: //170919/533D512BB256/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Jan 28 01:07:00.540: //170919/533D512BB256/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
Jan 28 01:07:00.540: //170918/533D512BB256/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=170918
Jan 28 01:07:10.956: //170918/533D512BB256/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x86F16B50, Call Id=170918
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jan 28 01:07:10.956: //170918/533D512BB256/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=170918
Jan 28 01:07:10.956: //170919/533D512BB256/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Start Calling Accounting;
   Call Entry(Incoming=FALSE)
   Cause Value=16, Call Entry(Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jan 28 01:07:10.956: //170919/533D512BB256/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jan 28 01:07:10.956: //170918/533D512BB256/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Call Entry(Incoming=TRUE)
   Cause Value=16, Call Entry(Disconnect Cause=16)
Jan 28 01:07:10.956: //170918/533D512BB256/CCAPI/cc_api_get_transfer_info:
Jan 28 01:07:10.956: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
Jan 28 01:07:10.960: //170918/xxxxxxxxxxxx/CCAPI/cc_api_request_rt_packet_stats_done:
   CALL_ERROR_INFORMATIONAL; tag not properly returned from SPI
Jan 28 01:07:10.960: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
   ExpectFactor=0xA
Jan 28 01:07:10.960: //170919/533D512BB256/CCAPI/cc_decr_if_call_volume:
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
Jan 28 01:07:10.960: //170919/533D512BB256/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86194F68, Tag=0x0, Call Id=170919,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 28 01:07:10.960: //170919/533D512BB256/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
Jan 28 01:07:10.960: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 28 01:07:10.960: :cc_free_feature_vsa freeing 88844970
Jan 28 01:07:10.960:  vsacount in free is 1
Jan 28 01:07:10.960: //170919/533D512BB256/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x88624DFC]
Jan 28 01:07:10.964: //170918/533D512BB256/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86F16B50, Tag=0x0, Call Id=170918,
Jan 28 01:07:10.964: //170918/533D512BB256/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
Jan 28 01:07:10.964: //170918/533D512BB256/CCAPI/cc_delete_call_entry:
   ccFreeRawMsgInfo=0x86EBD310
Jan 28 01:07:10.964: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 28 01:07:10.964: :cc_free_feature_vsa freeing 88844A50
Jan 28 01:07:10.964:  vsacount in free is 0
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=0
   Deleting profileTable[0x8862610C]
Jan 28 01:07:10.968: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
Jan 28 01:07:10.968: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
   CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
mdobiac
Level 3
Level 3
Mr. Andrey,
Here is a link to some information that may help you in achieve what you want in regards to your configuration:
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html#wp1282026
The section that will be important to you is the Answer Addres for VOIP.
Hope this helps.
Michael D.
Network Engineer | Cisco Technical Support
Hello Michael ,
Thanks for reply. As far as I understood this answer-address is used to match a dial-peer.
My problem is that incoming call matches a particular dial-peer but translation rule that I applied to this dial-peer does not reject a call for some reason.
