CallConnector Operator - How to Configure with CC Server
invtechnologies
I have a Smart CallConnector server setup and fuctional.  The Advanced Client works fine.
Want to setup the Operator Console but the only install that I have found is the Stand-Alone version.  Is this the version that I should use?  It is installed on a PC, but I cannot figure out how to set it up to use the server.
Thanks!
Jeremy Koch
yes champ, you need the client version. Uninstall the standalone version and get the client version and install
UC540 system with 8.6.2 Software Pack
Is there another place to get the software?  The download site connected to the community only lists the Stand Alone version and we did not purchase support with the software.
