04-22-2013 04:19 AM - edited 03-21-2019 07:15 AM
Hi all,
I have conected SPA112 ATA to UC 560. I can make calls from but not to SPA112 ports. in ccsip debug i see that UC is trying to reach spa trough outside sip-server. I added spa through cli becouse when i add it trough cca it disables sip trunk witch is my only trunk for outside calls.
Any idea how to make dial-peer and force UC to use it when calling spa extensions. all calls to spa extensions are made from same number whith is conneected to UC fxs port as Common area phone.
thanx for all replies,
BR,
Goran
04-22-2013 05:39 AM
You do not make a dial-peer. You have the SPA register to UC500, then will it recieve calls to the registered address.
04-22-2013 06:47 AM
spa extensions seem to be registered according to spa gui line status and i can make outging calls. I have same configuration on another site only diference is that there i am using BRI interfaces for PSTN and not sip trunk.
BR
04-22-2013 11:41 AM
Check that you do have bound sip to any interface.
