Can I duplicate phone button settings?
sam.grabowski
I have 14 phones all with side carts that need full programming.  I was hoping to program one set then clone it to the rest.
One idea I had was to program one phone then save the config to a cfg file on my computer and edit it by hand then restore the config.
would prefer to clone the keys via the web GUI if there is a proper way.
Am I missing something in the interface which allows me to do this?  I would like to avoid programming hundreds of keys manually.
Thank you,
danplacek
Level 4
Level 4
I have requested this feature before as well.
It does not yet exist.
I would also recommend against manual config editing -- the UC320 is very.... sensitive.
