can I use SPA303 as an analog phone instead of VOIP?
support0223
I don't believe this is possible but my searches have not come up with a definitive answer. Can the SPA-303 be used as a regular analog phone?
Jaime Valencia
The phone needs to be controlled via SIP or SPCP, no support for anything else.
java
if this helps, please rate
Jaime Valencia
java
Thanks for the quick response.
