Can VM Disti List contain nonsubscriber numbers?
Daniel Hoffman
Customer would like to create a poor man's outbound dialer using the ability of CUE to send messages to nonsubscribers. In order for this to work, they need to build a distribution list that contains PSTN telephone numbers. According to the documentation for the UC500, the disti lists on CUE may contain, among other entities, blind addresses, but I don't know what qualifies as a blind address. Is this possible with CUE?
Saurabh Verma
Level 4
Level 4
Hi Daniel,
CCA currently cannot configure this feature. You will need to use CLI for this. I think you may want to configure these as non-subscribers instead of blind. The non-subscriber numbers are tested against a restriction table (if configured), other than that, there is no restriction for non-subscribers.
HTH,
Saurabh
