Choose the line depends on dialed number
It seems that every line (extension) has own dial plan.
Anyway to pick the right line depends on dialed number?
For example, I have two totally separated PBX. One has internal numbers starts from "1" and another starts from "2". They are assigned to two lines, respectively.
Now I first have to manually pick the right line depends on number I'm going to dial.
Would be great to automate it. Any tricks for that?
Dan Lukes
Call routing is PBX/call manager task, not the phone's.
Well, you asked for trick ...
.. let read DialPlan string for SPA122 with <@sip-operator;uid/usr= ; pwd= >
It may or may not work even for your device (note you didn't mentioned what device we are speaking of).
Interesting, I'll try, thanks.
My devices are SPA3xx/5xx.
Dial plan is also kind of call routing but exist in phones (otherwise you wouldn't want to have it at all because dial plans always exist in PBX too). For example, Siemens phones allow to choose the line depends on dialed number. So, lack of this function is not axiom.
Let us know you succeeded (and consider rating of usefull advices then ;-) ).
"Call routing is PBX/call manager task, not the phone's." refer to Cisco SPA IP phones only (remember the community we are in).
