Cisco ATA 187 on UC560
Peter_sgc_2
Beginner
Beginner
Is the Cisco ATA 187 supported on the UC560 ?
Alexander Maroukian
Rising star
Rising star
Hello Peter,
Unfortunately it is not supported.
Alternatively you may use the old ATA186 or SPA8800, SPA8000
HTH,
Alex
*Please rate helpful posts
9 Replies 9
Alexander Maroukian
Rising star
Rising star
Hello Peter,
HTH,
Alex
No one at Distrubution sells the ATA 186
Peter_sgc_2
Beginner
Beginner
So seeing as the ATA186 is end of life.
Does the UC560 Suppot the "SPA112 2 Port Phone Adapter"
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps10024/ps10029/datasheet_C78-691106.html
Same asnwer as above, any SIP based adapter can be used with UC500 or CME.
paolo bevilacqua
You can use configuring it manually as third-party SIP phone, using CLI.
However the results will not be good as if using FXS port in UC500, or legacy ATA models that support SCCP.
Aha, So it's the case of Configuring it via the CCA?
It would need to be a Generic SIP Phone? Does this mean the configuration would need to be done by hand in the CLI of the UC500?
I would use the FXS ports but this is for a remote office where they EXT's are going over a VPN.
So I wanted to break out one of the EXT to an Analouge device for the use of an External Bell.
Prehaps with SNR or Call FWD etc...
Hello Peter,
In case of configuring with CCA use SPA8800, SPA8000 as they are the supported ones with CCA.
HTH,
Alex
Dam, the SPA8000 is a lot more then the SPA112
You can do that using a SIP device and SNR to that number. You can also use a device like algo 8180 that comes with a loudspeaker.
I do not know nothing about CCA. I know all works fine with CLI.
