Cisco BE6K deployment
Currently, We just want Internal Local Voice Calling fearures Across Campus. & We are planning to take Cisco Business Edition 6000 as Communication Manager.    We do not want to Connect PSTN at this stage.  SO, For IP Phone to IP Phone calling , DO we require additional Voice Gateway with Cisco BE6K??
sandeep
Jaime Valencia
No, If all you want is calls between IP phones there is no need for any GW.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Javalenc,
Thanks for the quick response.
And How many concurrent calls at same time can be support by BE6K??
