I want to know about the followings support,
Firstly, does UC 540 support CME 8.6? if yes then is it support SPA 500 series phones? if yes then can UC-540 register these phones over WAN using SSL vpn tunnels?
Second, does cisco jabber in iPhone supported by UC540 over WLAN as well over SSL vpn tunnels using CME 8.6 version?
Thirdly, does Cisco CCA 3.2 supported by UC540 for configuration? if yes then what is the requirement to run this tool?
Thanks in advance.
