Sure you can use the standard UCL (or CUWL SKUs for others reading this), just ensure that you select the correct volume band (A for below 1000 users).
If one of the earlier BE6000 models was purchased (Hardware and Software single SKU), it is also ok to use R-CBE6K-K9 to upgrade these.
Hope that helps,
Andy
