Configuring SPA901 with UC540
webstercomputer
Have a UC540 and a couple of SPA502 & SPA303's which have been setup and are working pretty well.  I am trying to add a SPA901 phone and not having much luck.  If i set the SPA901 to DHCP it gets an ip on the data vlan not the voice vlan.  If I give the SPA901 a static IP on the voice vlan i can not see it, ping it or access it (have set the gw as the voice vlan gateway.
I am led to believe it is possible to load a config for the SPA901 but have not been able to 1) find the config file or 2) find out where/how to load it.
any help would be greatfully appreciated
cheer
trgood
Hi Robert,
I don't think the SPA901 is officially supported on the UC500.  However you may try a configuration like the following:
https://supportforums.cisco.com/message/1128844#1128844
As for the Voice VLAN, I will look at page 99 of the admin guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa_9X1_admin.pdf
-Trent Good
** Please rate useful posts! **
-Trent Good ** Please rate useful posts! **
