11-19-2013 07:26 AM - edited 03-21-2019 07:55 AM
Hi, I'd like to know if it's possible consult data from external application... I'm doing an application, and I'd like to "integrate" with the telephones, Call Foprwarder, DND, PhoneBook.
So, it's possible to consult data, with a post or get, or anything... when I make a CallFordward, or DND, or insert, delete a contact in the phonebook??
Thanks a lot!!
Solved! Go to Solution.
11-20-2013 04:06 PM
It seems that my not so good English together with your's English will turn this dialog into true challenge ...
Are you asking how turn on debugging ? Then read here:
But if you are asking for list of events that trigger specific debug message or for list of debug messages and their meaning, then you are out of luck. Just try it. If an event of your interest will generate useable debug message, then you are lucky.
11-20-2013 09:56 AM
No. But you can turn on debugging on your device, direct it to your application and analyze them to reveal user activities.
But you are not first with such idea. Search for CallCtrl.
11-20-2013 03:16 PM
Historia Dan... trans por answerd to me...
I'll look the callctrl, but hot can i do What you hay about debugging?
I think, i believe, What turno on debugging te device, te phone, tell me all, if i activate dnd, cfwd......
It's true? That to outgoing activities, not ? Año incoming?
Thanks .....
11-20-2013 04:06 PM
11-21-2013 06:15 AM
Ok Dan..
Thanks for all.
