Correct regional settings for SPA2102 in Finland?
I have purchased stock Linksys SPA2102 ATA adapter with no operator configuration. By default all settings are for US phone devices.
Which settings I should change that my SPA adapter would be perfectly configured to operate together with PSTN devices intented for Finnish telecomm market?
It's pretty obvious that on the "Regional" settings the "Caller ID Method:" should be  "DTMF(Finland,Sweden)".
I have also changed the
Dial Tone: 425@-10; 10(*/0/1)
What other changes are recommended?
Patrick Born
Hi Jarno,
Consider contacting the service provider that you're using and asking them.
Also perform a search for your service provider and SPA2102, SPA3102, PAP2T, SPA400, or SPA9000.
Any of these would have similar regional settings that you could replicate.
Good luck,
Patrick
