Digital premicell
Luis Croquer
I have a problem with incoming call to a digital premicell, outgoing calls have no problem.
When I call to the number of the SIM at the premicell the call is ended
I get some debugs from incoming call and one for an outgoing call
The number of the SIM at the premicell is 672141387 and the number from I was calling is 6793290270
I think the problem is beacuse the premicell sent this info (isdn_info=2265546396l) to the BRI interface, but I'm not pretty sure of that.
These are the debugs of the calls.
UC540#debug isdn error
001081: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
        L2: sapi 0 tei 127 ces 0 ev 0x3
001082: ISDN BR0/1/0 Error: Invalid DSL (0)  SERROR: isdn_get_name_from_gtd: false ret
UC540#debug isdn events
001083: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0xE calltype 2 HOST_INCOMING_CALL
001084: ISDN BR0/1/0 EVENT: host_incoming_call: call_id 0x000E, Guid = 9F1212FE800C bchan 0
001085: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0xE calltype 2 HOST_DISCONNECT_ACK
INCOMING
UC540#debug isdn events detail interface BRI0/1/0
001118: ISDN BR0/1/0 EVENTd: isdn_get_guid: Got Guid 57D2DBBD800E
001119: ISDN BR0/1/0 EVENTd: calltrkr_incoming_call: call_id=0x10
001120: ISDN BR0/1/0 EVENTd: calltrkr_setup_received: isdn_info=2265546396l, call_id=0x10 ANSWER
001121: ISDN BR0/1/0 EVENTd: calltrkr_setup_received: calltracker disabled
001122: ISDN BR0/1/0 EVENTd: host_incoming_call: (non-POTS) VOICE call
001123: ISDN BR0/1/0 EVENTd: calltrkr_setup_received: isdn_info=2265556696l, call_id=0x10 ANSWER
001124: ISDN BR0/1/0 EVENTd: host_incoming_call: (1) call_type is VOICE
001125: ISDN BR0/1/0 EVENTd: host_incoming_call: voice_answer_data = FALSE call type is VOICE ALAW
001126: ISDN BR0/1/0 EVENTd: host_incoming_call: Received a VOICE call from 2005 on B1 at 64 Kb/s
001127: ISDN BR0/1/0 EVENTd: host_incoming_call: Accepting call call id 0x10
001128: ISDN BR0/1/0 EVENTd: host_incoming_call: Found CDAPI application for calltype VOICE
001129: ISDN BR0/1/0 EVENTd: process_bri_simple: msg 7, call id 0x10, bchan 0, call type VOICE
001130: ISDN BR0/1/0 EVENTd: process_disconnect: call id 0x10, call type is VOICE, b_idb 0x870992E4, ces 1, cause Invalid number format (incomplete number)(0x1C)
001131: ISDN BR0/1/0 EVENTd: calltrkr_call_disconnected: isdn_info=0x8709A6D8, call_id=0x10
001132: ISDN BR0/1/0 EVENTd: process_disconnect: Raw Release Message
001133:         0502010010040802FF9C0802809C
001134: ISDN BR0/1/0 EVENTd: process_rxstate: cause=0x10 (16), cause_present=1
001135: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x87097E9C, call_id=0x10
001136: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x8709A6D8, call_id=0x10
001137: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x8709A6D8, call_id=0x10
001138: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x87097E9C, call_id=0x10
001139: ISDN BR0/1/0 EVENTd: host_disconnect_ack: call type is VOICE
OUTGOING
UC540#debug isdn events detail interface bri0/1/0
debug isdn event detail is      ON.
001204: ISDN BR0/1/0 EVENTd: isdn_get_guid: Got Guid 9E9771D4836BReceived pdata len 0x3F data:1C 39 9E 1 0 3 67 74 64 0 0 0 2E 49 41 4D 2C D A 47 43 49 2C 39 65 39 37 37 31 64 34 35 30 35 61 31 31 65 33 38 33 36 62 62 31 66 63 62 39 64 35 31 35 37 30 D A D A 1E 2 81 83
001205: ISDN BR0/1/0 EVENTd: process_bri_call: No name in GTD
001206: ISDN BR0/1/0 EVENTd: process_bri_call: Name Modified by Calldecode
Name Type 0x0, cs 0x0, ie_val 0x28, pi 0x0, avail 0x0
        fachd len 0x0 data:
        inpdu len 0x0 data:
        name len 0xC data:4C 75 69 73 20 43 72 6F 71 75 65 72
001207: ISDN BR0/1/0 EVENTd: calltrkr_setup_received: isdn_info=2265546396l, call_id=0x8034 ORIGINATE
001208: ISDN BR0/1/0 EVENTd: calltrkr_setup_received: calltracker disabled
001209: ISDN BR0/1/0 EVENTd: isdn_get_name
001210: ISDN BR0/1/0 EVENTd: isdn_init_name_iecs: Clng Name SS Down
001211: ISDN BR0/1/0 EVENTd: isdn_get_name:
Name Type 0x3, cs 0x0, ie_val 0x28, pi 0x0, avail 0x0
        fachd len 0x0 data:
        inpdu len 0x0 data:
        name len 0x0 data:
001212: Nov 19 14:06:38.997: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 656970379 N/A
001213: ISDN BR0/1/0 EVENTd: calltrkr_call_connect: isdn_info=0x8709A6D8, call_id=0x8034
001214: ISDN BR0/1/0 EVENTd: calltrkr_call_connect: hndl=0l, cntrl_slot=0, cntrl_port=1, cntrl_channel=1.
001215: ISDN BR0/1/0 EVENTd: host_connect: Connected to 656970379 on B1 at 64 Kb/s
001216: ISDN BR0/1/0 EVENTd: process_rxstate: cause=0x10 (16), cause_present=1
001217: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x87097E9C, call_id=0x8034
001218: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x8709A6D8, call_id=0x8034
001219: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: hndl=0, cause=16, Normal call clearing
001220: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x8709A6D8, call_id=0x8034
001221: ISDN BR0/1/0 EVENTd: host_disconnect: call to <unknown> terminated
001222: Nov 19 14:06:40.337: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from 656970379 , call lasted 1 seconds
001223: ISDN BR0/1/0 EVENTd: process_release_req: Raw Release Message
001224:         1E0201803400
001225: ISDN BR0/1/0 EVENTd: process_rxstate: cause=0x10 (16), cause_present=1
001226: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x87097E9C, call_id=0x8034
001227: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x8709A6D8, call_id=0x8034
001228: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x8709A6D8, call_id=0x8034
001229: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x87097E9C, call_id=0x8034
001230: ISDN BR0/1/0 EVENTd: host_disconnect_ack: call type is VOICE
UC540#debug isdn standard interface b0/1/0
001141: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x01
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0180, '2005'
                Plan:ISDN, Type:Unknown
        Sending Complete
001142: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
001143: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x12 calltype 2 HOST_INCOMING_CALL
001144: ISDN BR0/1/0 EVENTd: isdn_get_guid: Got Guid DF95094F8010
001145: ISDN BR0/1/0 EVENT: host_incoming_call: call_id 0x0012, Guid = DF95094F8010 bchan 0
001146: ISDN BR0/1/0 EVENTd: calltrkr_incoming_call: call_id=0x12
001147: ISDN BR0/1/0 EVENTd: calltrkr_setup_received: isdn_info=2265546396l, call_id=0x12 ANSWER
001148: ISDN BR0/1/0 EVENTd: calltrkr_setup_received: calltracker disabled
001149: ISDN BR0/1/0 EVENTd: host_incoming_call: (non-POTS) VOICE call
001150: ISDN BR0/1/0 EVENTd: calltrkr_setup_received: isdn_info=2265556696l, call_id=0x12 ANSWER
001151: ISDN BR0/1/0 EVENTd: host_incoming_call: (1) call_type is VOICE
001152: ISDN BR0/1/0 EVENTd: host_incoming_call: voice_answer_data = FALSE call type is VOICE ALAW
001153: ISDN BR0/1/0 EVENTd: host_incoming_call: Received a VOICE call from 2005 on B1 at 64 Kb/s
001154: ISDN BR0/1/0 EVENTd: host_incoming_call: Accepting call call id 0x12
001155: ISDN BR0/1/0 EVENTd: host_incoming_call: Found CDAPI application for calltype VOICE
001156: ISDN BR0/1/0 EVENTd: process_bri_simple: msg 7, call id 0x12, bchan 0, call type VOICE
001157: ISDN BR0/1/0 EVENTd: process_disconnect: call id 0x12, call type is VOICE, b_idb 0x870992E4, ces 1, cause Invalid number format (incomplete number)(0x1C)
001158: ISDN BR0/1/0 EVENTd: calltrkr_call_disconnected: isdn_info=0x8709A6D8, call_id=0x12
001159: ISDN BR0/1/0 EVENTd: process_disconnect: Raw Release Message
001160:         0502010012040802FF9C0802809C
001161: ISDN BR0/1/0 CDAPI: cdapi_mib_update msg CALL_DISC, remote number 2005, connected? No
001162: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
001163: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
        Cause i = 0x809C - Invalid number format (incomplete number)
001164: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
        Cause i = 0x8290 - Normal call clearing
001165: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x12 calltype 2 HOST_DISCONNECT_ACK
001166: ISDN BR0/1/0 EVENTd: process_rxstate: cause=0x10 (16), cause_present=1
001167: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x87097E9C, call_id=0x12
001168: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x8709A6D8, call_id=0x12
001169: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x8709A6D8, call_id=0x12
001170: ISDN BR0/1/0 EVENTd: calltrkr_call_cleared: isdn_info=0x87097E9C, call_id=0x12
001171: ISDN BR0/1/0 EVENTd: host_disconnect_ack: call type is VOICE
001172: ISDN BR0/1/0 CDAPI: cdapi_mib_update msg CALL_DISC, remote number , connected? No
001173: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
UC540#debug isdn tgrm interface bri0/1/0
001174: ISDN BR0/1/0 TGRM: get_tgrm_avail_state: idb 0x87096AA8 bchan 1 service_state 0 call_state 2 false busy 0x0 dsl 2
001175: ISDN BR0/1/0 TGRM: update_tgrm_call_status: idb 0x87096AA8 bchan 1 availability state 1 call state(prev,new) (0,2), dsl 2
001176: ISDN BR0/1/0 TGRM: update_tgrm_call_status: Calling TGRM with tgrm_call_isdn_update: idb 0x87096AA8 bchan 1 call state 1 call type 2 call dir 1
001177: ISDN BR0/1/0 TGRM: get_tgrm_avail_state: idb 0x87096AA8 bchan 1 service_state 0 call_state 2 false busy 0x0 dsl 2
001178: ISDN BR0/1/0 TGRM: update_tgrm_call_status: idb 0x87096AA8 bchan 1 availability state 1 call state(prev,new) (2,2), dsl 2
001179: ISDN BR0/1/0 TGRM: update_tgrm_call_status: Calling TGRM with tgrm_call_isdn_update: idb 0x87096AA8 bchan 1 call state 1 call type 2 call dir 1
001180: ISDN BR0/1/0 TGRM: get_tgrm_avail_state: idb 0x87096AA8 bchan 1 service_state 0 call_state 2 false busy 0x0 dsl 2
001181: ISDN BR0/1/0 TGRM: update_tgrm_call_status: idb 0x87096AA8 bchan 1 availability state 1 call state(prev,new) (2,2), dsl 2
001182: ISDN BR0/1/0 TGRM: update_tgrm_call_status: Calling TGRM with tgrm_call_isdn_update: idb 0x87096AA8 bchan 1 call state 1 call type 2 call dir 1
001183: ISDN BR0/1/0 TGRM: get_tgrm_avail_state: idb 0x87096AA8 bchan 1 service_state 0 call_state 0 false busy 0x0 dsl 2
001184: ISDN BR0/1/0 TGRM: update_tgrm_call_status: idb 0x87096AA8 bchan 1 availability state 1 call state(prev,new) (2,0), dsl 2
001185: ISDN BR0/1/0 TGRM: update_tgrm_call_status: Calling TGRM with tgrm_call_isdn_update: idb 0x87096AA8 bchan 1 call state 0 call type 0 call dir 1
johschaf
Level 4
Level 4
This is the number we see coming in: 2265556696l
This is the error we generate:
It doens't appear the number is in the correct format. It looks like there is an "L" at the end. Do you know why we see the letter as part of the number?
-john
Hello John!
I have no idea, this device used to be used by other telephone company and was unlocked, maybe the "L" is becasuse of that, what you think?
By the way, that number doesn't match with the number of the SIM or the incoming call number.
All I can tell you is that we don't like that "number". Regardless of the number being sent to us, it has to be a valid number.
-john
