11-10-2011 09:44 PM - edited 03-21-2019 04:55 AM
Bit of a noob when it comes to this but I need to send 1 of the outside lines to a specific extension and all the other
PSTN lines to one other extension.
I also need to create a schedule to forward one line to an external number ( call forwarding ) then to a specific ext.at other times.
I am currently reading the 600+ page Cisco Configuration Assistant SBCS Administrator Guide but am hoping to get this done soon.
Thank you for your help.
Solved! Go to Solution.
11-11-2011 09:29 AM
Hello Leo,
The first part, directing specific calls to extensions can be configured in CCA under - Configure > Telephony > Dial-Plan > Incoming Direct-Dialing tab...
The second part is a little more tricky. To schedule a call forward at specific times, you can create a "floating extension", put a call-forward all on that extension to the specific extension you would like. Then you can setup "night-service" for that floating extension to forward to a different extension according to the night serivce schedule.
Thank you,
Darren
11-11-2011 09:29 AM
Hello Leo,
Thank you,
Darren
11-11-2011 09:55 AM
Hi Darren-
Thank you so much for your help. I will implement this on Monday and let you know how it worked.
Leo
11-14-2011 10:21 PM
Darren-
You are the bomb- I got the Line set up properley- I am still going to hack out the schedule bit. Thanks for the help.
