02-08-2012 09:51 AM - edited 03-21-2019 05:18 AM
Hi voice team!!!
My ip phone is registered on CME 7.1, but the Do not disturb is enable... and the device is not doing sound ringing...
The ephone template does not have the DND button...
And, I did the "no dnd feature-ring" on the ephone, but I didn´t have the solution...
ephone-template 1
softkeys idle Redial Gpickup Cfwdall
softkeys connected Trnsfer Park Confrn
codec g729r8
type 7911
In summary the command bellow shows the ip phones with dnd enabled... It is my problem...
GW_SESCPONTAGROSSA#sh ephone dnd
ephone-1[0] Mac:2037.0617.7348 TCP socket:[3] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:10.104.0.98 33056 7911 keepalive 61 max_line 1 available_line 1 DnD HuntGroupLogout
button 1: dn 1 number 2831 CH1 IDLE CH2 IDLE huntGroupLogout
Preferred Codec: g729
ephone-11[10] Mac:2037.0617.7511 TCP socket:[2] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=5
IP:10.104.0.93 38759 7911 keepalive 59 max_line 1 available_line 1 DnD HuntGroupLogout
button 1: dn 11 number 2841 CH1 IDLE CH2 IDLE huntGroupLogout
ephone-19[18] Mac:E8BA.7007.1783 TCP socket:[6] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=5
IP:10.104.0.95 30912 7911 keepalive 56 max_line 1 available_line 1 DnD
button 1: dn 19 number 2849 CH1 IDLE CH2 IDLE
ephone-22[21] Mac:88F0.7789.99C0 TCP socket:[9] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=5
IP:10.104.0.94 22346 7911 keepalive 54 max_line 1 available_line 1 DnD HuntGroupLogout
button 1: dn 22 number 2852 CH1 IDLE CH2 IDLE huntGroupLogout
thanks.
02-10-2012 11:56 AM
I did the reload and DND is not active.
thanks all.
