07-12-2015 06:13 AM - edited 03-21-2019 08:43 AM
I have problem with Voice, when I setup default settings of sip registration (UDP, 5060). I heed to setup 5065, TCP. And I haven't found SIP transport in web setting of this VoIP.
07-21-2015 02:17 AM
If you're trying to change the SIP port onto the router then you can configure as below:
voice service voip
shut
sip
listen-port non-secure 5065
exit
no shut
exit
The default transport protocol would be TCP. You can confirm the change using the show command "show control-plane host open-port".
Kindly confirm if this resolves your query or if you need any further info.
Akshay
10-19-2015 11:37 AM
This discussion has been reposted from Small Business Support Service to the SPA IP Phones community.
12-07-2015 10:38 PM
I tried to find SIP Transport in the settings of my IP Phone, but i hadn't found.
There was no possibility to configure my router TP-Link TL-3420 (this router is for home users).
12-08-2015 08:36 AM
Start new thread for brand new question, please.
Don't forget to mention what's relationship between SIP Transport mode and TL-3420 router. I suspect your issue can't be solved by TCP SIP transport mode.
