01-13-2012 02:02 PM - edited 03-21-2019 05:11 AM
So I stumbled upon this while reading traffic on our Sonicwall router and noticed that we're dropping about 50 packets per seconds. Is there any way we can disable multicast moh 239.10.16.16 port 2000 on the telephony-service section without affecting moh?
This is on our UC540.
-Renato
05-30-2012 11:33 AM
Hi Renato, I'm looking for a solution to the multicast problem too, but I think I can see 2 problems with your access-list:
I will search the configuration for the IGMP issue, or may be I could get some help here too.
Regards.
05-30-2012 06:44 PM
HI All,
I see this post re-surfaced again
I am not sure why there is such a concern about Music On Hold, it is a Multicast setup, meaning that it is not broadcasting unless there is an interested party for it, unless you physically alter its settings to be Unicast or a constant broadcast, MoH will only ever Multicast when an interest party has requested I.E.... EXT-100 places EXT-101 on hold, or EXT-100 places outside call on hold, then and only then it should be broadcasting.
Also the amount of traffic it generates is quite small given also the file size and compression of the file type as well, in hundreds of UC deployments I have never ever seen this come up as an issue, although when you plug in an outside source, I have seen some unwelcome traffic increase, but even then not enough to cause an issue on the network as it should be contained within its own VLAN.
Ofcourse unless something has changed and or I have had it wrong all along, which is very possible....
Cheers,
David.
