Explanation for the Softkeys on the SPA IP Phones?
dasasse
Is there any document that explains the Softkeys in more detail?
Beside the abbreviations it is sometimes not clear which function which softkey offers.
Daniel
2 Accepted Solutions
Alberto Montilla
Dear Sir;
I suggest you check the Quick Setup/Reference Guides, in the documentation section. It provides an explanation for the soft-keys.
https://www.myciscocommunity.com/docs/DOC-2880
Alberto
klogata
In addition to the Quick Start Guides, the SPA 5XX User Guides have explanations of the softkeys:
http://www.cisco.com/en/US/products/ps10499/products_user_guide_list.html
For SPA 5XX: Keep in mind that with software release 7.3.7 (SIP) and 7.4.2 (SPCP), administrators can create their own softkeys and labels, so depending on the customization of the system, some softkeys may not be described in the general documentation.
If you are looking for the SPA9XX phones, the documentation is here:
http://www.cisco.com/en/US/partner/products/ps10033/tsd_products_support_series_home.html
Hope this helps.
Alberto Montilla
Dear Sir;
Alberto
klogata
Hope this helps.
Thanks Kerry and Alberto.
