04-21-2011 03:36 AM - edited 03-21-2019 03:59 AM
How do i configure on a UC560 Fax2Email with a SIP Trunk and T.38 like T.37 Fax to Mail with CCA?
Best regards,
Thomas
04-21-2011 05:30 AM
Not supported on the UC500. Fax to email is only supported on PSTN connections.
Adam Compton
04-21-2011 05:37 AM
I know that it is not supported and can't be configured with CCA, but it should be possible to configure Fax over IP with CLI.
How can i configure Fax over IP with CLI on a UC560?
Best regards,
Thomas
04-21-2011 05:49 AM
Faxing over SIP trunks can work if it is going to an FXS port. Fax to email is a different story. The TCL script used for fax to email can only use POTS dial-peers, thus not allowing SIP trunks fax to email.
Adam Compton
04-21-2011 06:42 AM
Is it enough to configure DID for a number and point it to an internal extension of a FXS port?
Would it then also be possible to send a fax?
What has to be configured for Fax to Email with a SIP trunk on a UC560 with CCA default settings?
Thomas
