Feature Access Codes for IP phones
Chris Foot
Beginner
Beginner
Hi All,
I'm having a small configuration issue with my uc540. I am trying to use the feature access code to enable/disable night service but I can't seem to get feature access codes working on my 7941 phones at all. Is there somewhere in CCA that I can enable this?
Chris
Alexander Maroukian
Rising star
Rising star
Hi Chris,
Yo may try to use another code which is not overlapping with the standard ones e.g. *222
Below are the standard ones:
telephony-service fac standard
  callfwd all **1
  callfwd cancel **2
  pickup local **3
  pickup group **4
  pickup direct **5
  park **6
  dnd **7
  redial **8
  voicemail **9
  ephone-hunt join *3
  ephone-hunt cancel #3
  ephone-hunt hlog *4
  ephone-hunt hlog-phone *5
  trnsfvm *6
HTH,
Alex
*Please rate helpful posts
