H.323-trunk -> works, but no function if an extension is forwarded
DetNit1101
Hello community,
i´ve set up a trunk between two UC500 with H.323.
Everything works fine, extensions are translated with correct node-numbers and so on,
calls are possible and missed calls can be answered correctly.
But if anyone calls over the trunk an extension which is forwarded (no matter: all, busy or noan to VoiceMail or to an other extension)
it doesn´t work; the A-side is disconnected immediately or after the noan-timer.
But if I call an free extension on side B and this extension makes a call transfer to an forwarded extension,
then it will work and I get the VoiceMail-Announcement on the side A.
The only hint with deb voice ccapi error
000147: Mar 11 11:48:45.235: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   Unsupported MLPP Service Domain Network 0
From internal extensions or PSTN does it work with call forwarding.
NODE 301
dial-peer voice 71 voip
description : SIP TOKYO
translation-profile incoming ankommend_von_TOKYO
translation-profile outgoing abgehend_nach_TOKYO
destination-pattern 501..
session target ipv4:11.2.10.198
incoming called-number 301..
dtmf-relay h245-alphanumeric
codec g711ulaw
supplementary-service h450.12
no supplementary-service h225-notify cid-update
telephony-service
transfer-system full-consult
transfer-pattern .T
NODE 501
dial-peer voice 90 voip
description : SIP
MOSKAU
translation-profile incoming ankommend_von_MOSKAU
translation-profile outgoing abgehend_nach_MOSKAU
destination-pattern 301..
session target ipv4:11.2.11.196
incoming called-number 501..
codec g711ulaw
telephony-service
transfer-pattern .T
also implemented on both systems:
voice service voip
ip address trusted list
  ipv4 11.2.11.192 255.255.255.192  /
ipv4 11.2.10.192 255.255.255.192
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service ringback h225-info
Kind regards,
DetNit
31 Replies 31
according to the way that I received an info on node 301
that the original call was redirected to extension 55 (CUE)
on node 501, I create the following config on node 301:
dial-peer voice 55 voip
translation-profile outgoing redirect_to_CUE_501
destination-pattern 55
session target ipv4:10.212.10.198
codec g711ulaw
voice translation-profile redirect_to_CUE_501
translate calling 71
translate called 73
voice translation-rule 71
rule 1 /^\(..\)/ /301\1/
voice translation-rule 73
rule 1 /^\(..\)/ /501\1/
And it works, I got the right mailbox 33 on node 501!
Or is this just a lousy work-around?
Kind regards,
DetNit
Hi DetNit,
OK best thing for me to do is give you an example of the WAN-2-WAN Configuration I have used, this may or may not help you but it could set you on the right path.... NOTE: Transcoding is required for this especially when Voice Mail comes into play, so you will need to get that working correctly.
After the configuratione example i will answer your above questions
Site A:
voice call send-alert
voice rtp send-recv
voice service voip
sip
  no update-callerid
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class cause-code 1
no-circuit
voice translation-rule 2002
rule 1 /^6/ //
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
This is the Voice Mail Pilot
dial-peer voice 2000 voip
destination-pattern 699
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
This is the Dial-Peers for Calling Site-2, you will need to modify this accordingly
NOTE: The destination pattern is the DN number for the remote site
dial-peer voice 2010 voip
description Incoming Call
incoming called-number .%
dial-peer voice 2011 voip
description ***UC1-CALLING-UC2***
preference 1
destination-pattern 640
session target ipv4:10.1.2.1
dial-peer voice 2012 voip
preference 1
destination-pattern 641
translate-outgoing called 600
dial-peer voice 2013 voip
preference 1
destination-pattern 642
dial-peer voice 2014 voip
preference 1
destination-pattern 643
dial-peer voice 2015 voip
preference 1
destination-pattern 698
codec g711ulaw
dial-peer voice 622 voip
destination-pattern 622
translate-outgoing called 622
codec g711ulaw
You may or May not want this DN but i tend to use it a lot and CCA puts it in as well
ephone-dn  86
number 7... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 699
The above configuration does not rely on translation rules, however this was only chosen because the remote site does not have many end points and would not require a very large dial-peer configuration, which by the way you are limited to how many you can do as DP's are resource intensive.
How the above Works:
Well when someone in site A dials say 642, dial-peer 2013 will be matched (possible others but this would be the identical one or the closest one) and it will follow the instructions within the dial-peer configuration, a call will be sent to site B.
Site B:
voice rtp send-recv
voice service voip
sip
  no update-callerid
voice class codec 1
voice-card 0
dspfarm
dsp services dspfarm
This is site B's Voice Mail Pilot
dial-peer voice 50 voip
b2bua
session target ipv4:10.1.11.1
codec g711ulaw
The following is a big dial-peer configuration as this remote site is talking back to the Head Office, but the resources could be afforded on this site
preference 1
destination-pattern 610
session target ipv4:10.1.1.1
preference 1
destination-pattern 611
preference 1
destination-pattern 612
preference 1
destination-pattern 613
preference 1
destination-pattern 614
dial-peer voice 2016 voip
preference 1
destination-pattern 615
dial-peer voice 2017 voip
preference 1
destination-pattern 616
dial-peer voice 2018 voip
preference 1
destination-pattern 617
dial-peer voice 2019 voip
preference 1
destination-pattern 618
dial-peer voice 2020 voip
preference 1
destination-pattern 619
dial-peer voice 2021 voip
preference 1
destination-pattern 620
dial-peer voice 2022 voip
preference 1
destination-pattern 621
dial-peer voice 2023 voip
preference 1
dial-peer voice 2024 voip
preference 1
destination-pattern 623
dial-peer voice 2025 voip
preference 1
destination-pattern 624
dial-peer voice 2026 voip
preference 1
destination-pattern 625
dial-peer voice 2027 voip
preference 1
destination-pattern 626
dial-peer voice 2028 voip
preference 1
destination-pattern 627
dial-peer voice 2029 voip
preference 1
destination-pattern 628
dial-peer voice 2030 voip
preference 1
destination-pattern 629
dial-peer voice 2031 voip
preference 1
destination-pattern 630
Some Examples of site B's DN's which might be helpful as you can see the call routing path
ephone-dn  10  dual-line
number 640 secondary XXXXX640 no-reg both
label Dept1-640
description Dept1-640
name Dept1-640
call-forward busy 698
call-forward noan 698 timeout 10
ephone-dn  11  dual-line
number 641 secondary XXXXX641 no-reg both
label Dept2-641
description Dept2-641
name Dept2-641
ephone-dn  12  dual-line
number 642 secondary XXXXX642 no-reg both
label Dept3-642
description Dept3-642
name Dept3-642
Some Notes: Site A and Site B work within a private network so do not use the above IP address ranges unless it falls within your networks subnet's, make sure these are changed accordingly. You will also note the lack of translation rules, whilst you can run them as well as the dial-peers it is recommended you choose one of them, if there is a heap of extensions and this amounts to a lot of dial-peers then you might need to use translation rules and dial-peer 2010 configuration.
Site B also has Direct Inward Dial numbers that are controlled from Site A, you might not have that but in this scenario you can use it it is quite useful if you want to give them DID's.
Ok the above is most likely not the recommended deployment of it, this was a make do configuration but it worked so it stayed that way
Answer to your question:
One question for the understanding :
If extension 15 on node 301 calls extension 33 on node 501
and this extension is forwarded to 55 (the CUE on node 501)
does node 501 inform node 301 about this?
And starts node 301 then a new call to extension 55 on node 501?
In this case, node 301 should dial 50155 to reach the CUE on the
other side, but how does the CUE on node 501 know to which
mailbox this call from 30115 is adressed?
Short answer is NO, Site-A only cares about itself and the rules applied to your configuration, if you have a CF-all to VM rule on a DN, then it will just follow that rule, Site-B wont know about this until it hits the VM, although there will be some background chatter that will take place, but the bulk of the chatter will be on the receiving end.
Brief Comment:
Remarks:
Node 501 is configured only with one subnet for UC, CUE and Phones
because the customer want to reach everything from remote without
NAT/PAT and he has no chance to change the routes in the MPLS by himself.
So I´ve got only a /27 to set the whole box up; it took me several hours, but it works.
Node 301 is an old system, just for the lab and it is used for every testings,
so there are many confusing config-parts.
Flat Network deployments are common when they reside on MPLS networks, I have only ever worked with 3 of them myself but as long as you have everything configured right with the routing, then all should be fine. NOTE: I am not a data expert, in fact I struggle with it a bit and rely on those around me who are experienced in it, I just love working with voice.
By the way, if you are running 2 digit extensions, can I convince you to go to 3 digit extension dialing? I wont go into why it is better now as that is an entirely different subject, but 3 or 4 digit dialing is the best to work with.
Ok eyes officialy hanging out of my head now, I need a cold beer and then urgently needed sleep.
Honestly the above is just a guide it may or may not help you, just give it your best shot if it doesnt work then maybe when I am in a better state i can try to help you out more.
Good luck and I wish you all the best, my apologies about the long post but heres to hoping it helps you out
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
