08-14-2011 07:48 PM - edited 03-21-2019 04:30 AM
HI everyone!!
My customers need Chinese voicemail.(I need China and Taiwan Locale Pack )
I can not find the Locale Pack on https://supportforums.cisco.com/docs/DOC-9829.
How can I change uc500 to chinese language (voicemail)?
I need help!!
Thank you everyone!!
08-14-2011 10:04 PM
The present SWP 8.2 only support Chinese(Mandarin) language, not Taiwan or Hong Kong.
The Taiwan and Hong Kong locales will be supported in the next SWP.
Please open a support case and we will publish the file(Chinese-Mandarin) to you via the case owner.
You will have to install Chinese language and activate it manually since CCA is not support it.
The case owner should be able to instruct you.
-David Liao
08-15-2011 07:58 AM
Thank you David.
I can not use CISCO TAC Service (ID is not set up to access).
I hope next SWP can support Taiwan and Hong Kong locales,and can download at https://supportforums.cisco.com/docs/DOC-9829.
Thanks again.
