07-02-2010 07:54 AM - edited 03-21-2019 02:44 AM
I was able to turn DHCP off to give a demo to a customer now how do I turn it back on?
Solved! Go to Solution.
07-02-2010 08:02 AM
In CCA, go to Configure > Routing > DHCP Server to create a new scope. Assuming you are using the UC500 for data and voice you will need a voice and data scope. You will also want to configure a range of exclusions for each scope - usually at least the first 10 addresses.
Hope this helps.
Brandon
07-02-2010 08:02 AM
Hope this helps.
Brandon
07-02-2010 09:20 AM
got it thank you.
