How long to "loading voice related data?"
JOHN THIEN
I have a UC540 and CCA 3.2.  I'm trying to access the Telephone/Users/Extensions/Voicemail and I'm getting a message that says "Loading voice related data" going on 18 minutes now.  Is that normal?
I have not setup VMail on this system, but I've done a lot of other work.  So if there is a problem, and some way to reset this component via telnet or something, I'm all ears.
Dennis Bigelow
Hi John,
You need to make sure you have access to the 10.1.10.0 subnet. Check and see if you can get to the CUE webpage (10.1.10.1). Also check your default gateway. If you are using another device other than the UC, you will need a route to the 10.1.10.0 subnet. Also make sure Windows firewall is turned off.
wclippar
From CCA You can also press "f2" which will show the transactions between CCA & UC5xx device.
Make sure you are using a supported Microsoft Operating System (Windows XP, Vista or 7)
Also make sure your PC has UC5xx as the default GW
Hope this helps,
Bucky
Thanks William.  I was all ready to try the F2 when I returned to the site today, BUT, it wasn't required.  I went into the "voicemail" feature in CCA and it just pretty much popped right up.
