04-26-2013 02:04 PM - edited 03-21-2019 07:17 AM
I just depolyed a customer with multiple 504 and 508's with the 500DS on each phone. They want one button to push for for paging.
Currently they have to do *96 dial 800 dial
How can I script this onto a button?
Solved! Go to Solution.
05-01-2013 05:07 PM
I'm sorry. I'm unable to repeat your configuration.
Even I configured Paging_Code to *96, the *96 dial 800 dial sequence doesn't work for me. After the first dial, the *96 is dialed (and rejected by PBX as unknown number). No further prompt on phone.
On the other side, I can dial 800 with no prefix to initiate the "pagging call" if 800 is configured in Group_Pagging_Script. I can save 800 into personal address book or call it using speed dial defined on Line Key (I have no SPA500DS here)
fnc=sd;ext=800
It just work. I need no *96 prefix for it.
May be, it doesn't work from SPA500DS only (then you should consider to configure SD function on phone's Line Key)
04-28-2013 06:44 AM
May be I just doesn't understand your question correctly (I don't know what you mean saying "*96 dial 800 dial") - but you should configure the pagging on attendant console the same way as you configured in on casual phone's line-key until now.
04-28-2013 08:13 AM
I want to make a button for paging, I have never put on on a line key before
I assume its something like fnc=sd;ext=*98800
The problem is that I have tohit the dial key in the middle.
so the user hits *98 (3 key pushes) then the Dial soft key (1 key push) then 800(3 key pushes) then the dial soft key again.
Sage
04-28-2013 10:23 AM
I pressed *96 on my phone followed by "dial" - the *96 has been dialed agains the PBX as standard number.
From your question I'm unable to recognize if "pagging via *98" is supplemental service of your PBX, or is matter of a specific configuration of your phone (but you didn't mentioned it).
Read Release Notes of 7.5.1a firmware, page 4. It may or may not help you.
04-28-2013 08:50 PM
Dan
I am trying to use the feature built into the spa phones. The paging feature is a multicast feature that does not matter what pbx you connect to.
This is the code that says what to dial first
This part says to listen to 800
I am looking to make a speed dial of this feature using the above codes.
05-01-2013 05:07 PM
fnc=sd;ext=800
