How to: Softkey on SPAxxx as shortcut to address book
GeniozzBV
Hi there,
Is there a way to link a softkey to the local address book with internal dial numbers? Default, you need to go through multiple menu options to finally get to this list. I was wondering if this can be arranged via a single softkey shortcut. I am talking about the SPA504 which is connected to a UC540.
The same goes for the outgoing call history. Can we put that list under a single softkey as well instead of browsing through the default menu??
Thanks in advance for your response!
Kind regards,
Ozz
William Paulsen
Does anyone have an answer to this question?  Thanks.
datak2011
i also need this feature, anyone have an answer ?
